Cruise Control
Discussion in 'Gen 2 Prius Fuel Economy' started by Justin Glose, Jan 8, 2013.
  1. Justin Glose
    Justin Glose Junior Member
    23
    Just curious to know the amount of time everyone uses CC while driving? I recently started using it and have seen great improvment in mpg.
    JG
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The more your driving is a steady speed over 47 MPH on dead flat ground, the better CC will do for you.
    Pulse and glide at lower speeds, and any elevation change work for manual control
  3. Justin Glose
    23
    JP,
    I'm famillar with gliding, could you please explain what it means to pulse? Thanks!
  4. PriusGuy32
    1,411
    506
    Harrison Township, Michigan
    Ive had the opposite result - using CC makes me get worse mpg's.
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Right, if your part of the country is not billiard table smooth, CC may be working the engine harder than it needs to.
    The lower Mississippi river valley is billiard table smooth, I can drive over 150 miles and gain 100 feet in elevation.
    A much larger area is almost that smooth, including parts of MO.
    In the shaded area, Cruise Control is not guessing wrong.
  6. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    I like cc. It is on for about 90% of my driving for open roads. I find it to do well for me. In town I do better. H
  7. Justin Case
    Justin Case Junior Member
    I generally get 2 mpg worse if I drive in Michigan (which is pretty flat) with CC. When I'm driving thru a a tank of gas the 60 cents is worth it to use cc.
    PriusGuy32 likes this.
  8. Pandalover
    Pandalover Junior Member
    82
    UK
    I use it for motorway driving during my commute. It keeps me in the speed limit and keeps my speed constant. Otherwise I often find my speed is quiet variable on a boring stretch of road.
