Cruise Indicator Lamp Does NOT Illuminate
Discussion in 'Gen 2 Prius Main Forum' started by ydpplqbd, May 24, 2022.
  1. ydpplqbd
    ydpplqbd Active Member
    542
    250
    Cruise indicator lamp NEVER illuminates.. However, cruise works perfectly. Is it real as simple as changing the bulb? If so, bulb size please.
  2. PriusCamper
    PriusCamper Senior Member
    11,109
    4,522
    Pacific Northwest, USA
    Never heard of a bulb failing in the dash... Perhaps its a loose connection? Maybe pull it out and inspect?
    ydpplqbd likes this.
  3. ChapmanF
    15,717
    Gen 1 had replaceable incandescent bulbs for its dash indicators; its parts diagram on parts.toyota.com shows them, with the part number.
    The Gen 2 parts diagram doesn't show any replaceable indicator bulbs there, so I assume those are all LEDs in Gen 2 and not expected to burn out.
    There could still be something going on with that circuit plate though.
    If you have access to Techstream, there is probably an active test to directly turn on that indicator. If it doesn't turn on then, that'd be direct evidence of a problem controlling the light. Have you noticed any other indicators behaving oddly?
    The repair manual and wiring diagram would probably be necessities for getting it sorted:
    Toyota Service Information and Where To Find It | PriusChat
    ydpplqbd and PriusCamper like this.
  4. ydpplqbd
    542
    250
    All fixed: hit a big pothole and now the CC indicator works.
    Next time that i have dash apart I will look for loose connections. Clearly the bulb works.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,485
    1,587
    NJ-USA
    I would look at the flex cable connections between the main circuit board in the Combination Meter and the sub board with all the indicator lights. I expect the hybrid control ecu to send a message to the CM- "hey turn the C/C indicator on". Then the controller in the CM (on the main board) would actually switch the LED indicator (on the sub board) on.
