Cruise is not working. Gen 2 08
Discussion in 'Gen 2 Prius Audio and Electronics' started by Jahras, Feb 6, 2020.
  1. Jahras
    Jahras New Member
    UK
    The cruise light will come on... and if I press down on the stalk cruise it will activate sometimes...and then just randomly stop.
    Not sure how to troubleshoot
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    First, check your brake light switch......to see if the lights come on sometimes when the pedal is NOT pushed or just barely touched.
    davecook89t likes this.
    52,805
    it's gonna be a tough process, with lots of knowledge and experience. there may be a troubleshooting tree in the repair manual.
    otherwise, do as the dealers do, start replacing parts one at a time, until it works.
    might likely be the clockspring
    SFO likes this.
  4. Jahras
    Jahras New Member
    UK
    Ok I will check this, I think this ould be it. Because sometimes cruise will set and then I will feel the car brake...
  5. Jahras
    Jahras New Member
    UK
    Sounds expensive... from what I read it could be the clockspring or brake light switch.. is there a definitive way to determine
  6. bisco
    52,805
    Yes, you have to check the connectivity from end to end with a meter
  7. Jahras
    Jahras New Member
    UK
    Is there a guide on this? after a while the cruise light will blink.... and the temperature fan buttons dont work on the wheel
  8. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    This confirms that your clockspring is bad. Make sure you use a genuine OEM clockspring and not a cheap eBay one unless you like going in and doing this replacement on a regular basis.
    SFO likes this.
  9. bisco
    52,805
    try turning the wheel from one stop to the other, while pushing the different buttons
