Curious: When parking, what do YOU do?
Discussion in 'Gen 3 Prius Main Forum' started by J5A, Jan 19, 2011.
  1. Mopar
    Mopar Junior Member
    Fort Worth Texas
    Have had the car about a month now. At first I pushed park and then power. In the first week I got distracted and left the car on for about and hour. After that I changed to being a power button only person. Eliminates possibility of repeating that mistake again.
    Roger
  2. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    I put it in park, set the emergency brake, and turn the ignition key to the off position. This allows the key to be removed from the ignition, and stored safely in my bag.
    Oh, wait, I don't drive a Prius.
    Never mind.
    Prieth likes this.
  3. tomtomsf
    tomtomsf Junior Member
    36
    Half Moon Bay
    I just turn it off. This sets it in park. It is one of the nice conveniences of the Prius.
    Tom G.
  4. Pinto Girl
    3,093
    350
    I believe the manual of the GII Prius advised that it's preferable to press park before powering down. What does the GIII manual say?
  5. bisco
    52,891
    i leave mine all the time so i can make a quick getaway. oh wait, i have a geetoo.:D
  6. Roadburner440
    Roadburner440 Member
    316
    59
    Hampton, VA
    I always hit park, and then the power button.. Occassionally I do forget to hit park, but the power button takes care of it if I don't. I think I have only left the Prius on once.. However I have accidentally left the Volt on a couple times on accident as it does not beep or anything like the Prius does if you leave it on.
  7. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    I am often reminded - by some beeping - to turn the power off - and this after I'm already out of the car.
    So I guess I must hit "Park" first.
    And that's when I'm not already being reminded by a different signal that I left the keys inside the car (with the power on).
  8. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I prefer to press park, P button when intending to park. I just like to get it out of gear soon to be safer. Could switch it up by setting parking brake, turning lights off, then pushing power button.
  9. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Actually just watched the 3rd gen quick reference DVD this evening. They demonstrate only using the power button when stopped as it sets the car in Park also. But, it's fine to push the P button first.
    I think the reason I push the P button first when parkign is it gives me a second to think about what to turn off, like the radio, and lights before powering off. I prefer having it in Park rather than just having the parking brake set before powering off.
    OTOH, getting distracted like reaching to pick something or trying to get out while in gear could be really bad!
  10. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Sometimes, I arrive at my destination in the middle of a phone conversation, and that's when I press Park. It kills the ICE if it's running and lets me either switch off Bluetooth or finish my call handsfree. This might sound like a corner case, but it happens a few times a week.
  11. Canuck
    Canuck Member
    605
    Vancouver Island,BC,Canada
    :focus: I've solved the problem by having my wife turn the Prius off. If you don't have one ( wife that is) I suggest you get one . They can be quite useful from time to time .......oh that hurt! ( wife is watching over my shoulder as I type this) ...really kidding:eek:
  12. mrnoyb
    mrnoyb Junior Member
    52
    NA
    The process must have changed for 2011 because there's no mention in the owners manual of any alternate method of setting "P".
    2-1. Driving Procedures (->P.152)
    Parking the vehicle
    With the shift position in “Dâ€, depress the brake pedal.
    Set the parking brake. (→P. 182)
    Push the “P†position switch. (→P. 176)
    When parking on hill, if necessary, block the wheels.
    Turn the “POWER†switch OFF and stop the hybrid system.
    Lock the door, making sure that you have the electronic key
    on your person.
  13. tomtomsf
    36
    Half Moon Bay
    The Prius DVD and the manual both say you can just hit the Power to turn it off. That automatically sets it in Park. Either way is fine, but for me, the less button pushing the better. Here's some info from the manual:
    Stopping the hybrid system
    Stop the vehicle.
    Press the “POWER” switch.
    Check that the shift position indicator on the instrument
    cluster is set in “P”.
    Set the parking brake. (→P. 179)
    Release the brake pedal and check that the indicator on the
    “POWER” switch is off.
    If you stop the hybrid system without setting the shift position to
    “P”, the shift position will be shifted to “P” automatically. You can
    also shift the shift position to “P” by pressing the “P” position
    switch.
