Current State of the Art in Battery Balancers?
Discussion in 'Gen 3 Prius Main Forum' started by jimolson, Jun 21, 2025.
  1. PriusII&C
    PriusII&C Active Member
    425
    142
    San Jose, California
    Thanks.
  2. PriusTech
    PriusTech Active Member
    247
    105
    Reno
    It would be interesting to see your start to finish process written out, even if it was a condensed version
    Finally got the battery reconditioned and into the Lexus. The Dr Prius full battery test was good. The life expectancy is good but it says 102% life which I'm guessing is inaccurate. It was tested right after install so expect the mAh to go down.
    Do you match battery blocks by putting high / low modules in each block for overall balance? What measurement do you use to determine high / low modules?
    How many cycles of discharge / charge do you usually do?
  3. gdanner
    gdanner Member
    134
    51
    Central Illinois
    Do not attempt to charge loose unclamped Prius modules. They will swell up to where they look like a large Subway sandwich. The one exception to this rule is that if you limit charging current to <600mA and make sure the module isn’t getting more than 10 degrees above ambient.
    Years ago I bought a pair of the white plastic end plates for the Prius HV pack on eBay. I usually stack 6 modules between the end plates. I clamp them with 4 long bolts and nuts. I never had any modules get bloated with this setup.
    PriusTech likes this.
  4. Carall
    Carall Active Member
    308
    104
    Harrisonburg, VA
    Lately, I've been starting with a discharge (to save time), then a charge, and so on for 3 cycles. 2 cycles is not enough, the voltage between the modules varies by 0.05 volts. One module is 8.00 volts, and the next one is 8.05 volts, and so on.
    It looks like this
    8.00
    8.05
    8.00
    8.05
    After three cycles, the voltage across modules usually looks like this
    8.00
    8.01
    8.00
    8.00
    8.01
    8.00
    Battery packs that just need capacity restored I do 3 cycles and after working on bus bars, I install it back into the car.
    Batteries that have trouble codes, I pinpoint bad modules in them, replace them, do bus bar work and then do 3 cycles, after that I put it into the car, discharge it to 40% and after 10 minutes I measure the voltage on the modules, looking so that there are no modules with a voltage lower than the rest by 0.1 volts or more.
    If a battery pack has a single P0A80 code, such a battery usually does not have obviously bad modules. I do 3 cycles, then I dothe bus bar work, after that I put it into the car, discharge it to 40% and after 10 minutes I measure the voltage on the modules, looking so that there are no modules with a voltage lower than the others by 0.1 volts or more.
    When a battery pack is old or with high mileage, I disassemble it and weigh each module by writing the weight on top of the module. I recently changed a battery pack in a 2012 Lexus ct200h with 195k miles. The battery pack with a single code P0A80. I weighed the modules and their weight was 1031-1034 grams, mostly 1033-1034 grams. Such a battery may still last for a couple of years, but you shouldn't rely on it much anymore.
    102% means that the recovery process has worked. This percentage will decrease and on a healthy battery it should stop at 70+% and it will stay that way for several years. The similar thing happens to module voltage. On a healthy battery sitting on a shelf, the voltage does not drop below 7.7 volts, even after a year.
    gdanner and PriusTech like this.
  5. ASRDogman
    ASRDogman Senior Member
    7,565
    3,903
    Did you not read everything???
    The battery overdrew power, accuracy was compromised.
    It as an ESTIMATED 102.57% capacity.
    So the app is NOT inaccurate.
    QUOTE: Finally got the battery reconditioned and into the Lexus. The Dr Prius full battery test was good. The life expectancy is good but it says 102% life which I'm guessing is inaccurate.
    #65 ASRDogman, Aug 22, 2025
  6. Carall
    308
    104
    Harrisonburg, VA
    I forgot to ask... how are things going with the P0A80 code now?
  7. PriusTech
    247
    105
    Reno
    It finally cleared. Apparently it's saved in memory because it won't clear even with a small battery disconnect. I think the system has to see a good battery, then it self clears. It took about 30 minutes of driving after the good battery was installed.
    I saw that about the overdraw. It's very tricky to keep it in range while testing, I'm still learning how to do it. I knew it was going to be a good test though because it ran the full 10 minutes. The previous 2 tests failed after about 4 minutes.
  8. PriusTech
    247
    105
    Reno
    thanks for taking the time to write this post
    So when you weigh the modules you're checking for fluid loss?
  9. Carall
    308
    104
    Harrisonburg, VA
    To load the gen 3 prius battery pack with 6.5 amps:
    I set emergency brake,
    put it into reverse,
    turn on the headlights with high beams,
    turn on the rear window defroster
    and the heater blower. By the blower, I regulate the needed consumption.
    Do not use the a/c, its load is not constant. The window defroster turns off automatically after a certain time, you need to monitor this.
    2 previous tests failed because the battery pack had weak modules. The discharge starts evenly and then it drops sharply and the test fails.
    Yes.
  10. gdanner
    gdanner Member
    134
    51
    Central Illinois
    Very Interesting: I just looked at the Harbor Freight shopping page. They currently offer 2 different inexpensive Viking battery testers:
    Price: $39.99 USD for either model.
    Harbor Freight also has this cheaper ($17.99 USD) analog unit:
    https://www.harborfreight.com/automotive/diagnostic-testing-scanning/battery-testing/load-testers/100-amp-612v-battery-load-tester-61747.html
    Is the digital Viking model the same one you have been using?
    Both analog testers look very much like the Neiko.
    As of today my local Harbor Freight store has the 2 analog models in-stock but not the digital one.
    I'm tempted to run out to their store and grab the Viking analog unit. It has the highest user rating among all of the Harbor Freight battery testers
  11. PriusTech
    247
    105
    Reno
    Yes I have the HF digital. The Neiko is 100 amp, you shouldn't go over 10 seconds, with the 135 amp HF I wouldn't go over 7 seconds
    I would get both, they both do different tests. The digital one checks 5 different things. The analog does just a load, but it's very similar to what the car does when you floor the gas. I've tested and condemned modules with both of them. It's best to test with these before you start a grid charge because when you find bad modules after a grid charge you have to start all over.
    gdanner likes this.
  12. gdanner
    gdanner Member
    134
    51
    Central Illinois
    I'm holding the test button just long enough to observe how far the meter needle moves. 1 second is long enough.
    I also have a multimeter with "max - min" capability. If I have this connected to the battery under test the difference between the two readings (test button pressed or released) will allow me to calculate the battery series resistance precisely.
    The "load" inside the tester is a simple resistor made out of very thick nichrome wire. I will test its actual resistance. It's likely to be in the neighborhood of 0.01 to 0.05 ohms. Aka 10 to 50 milliohms.
    Note: when testing a single Prius module (7.2V rather then 12V) the load current will be about 1/2 of the rated 135A. Just about right for a Prius.
  13. gdanner
    gdanner Member
    134
    51
    Central Illinois
    One useful thing about these inexpensive 12V car battery testers is that 1 or 2 seconds of their heavy load instantly reveals Prius modules which are seriously weak, either because of high internal resistance or a major loss of mAh capacity. And of course these testers are also useful for testing the Prius 12V lead-acid battery.
    Cautionary note: In my opinion, attempting to test two Prius modules in series causes excessive current drain. I think it's better to test individual Prius modules only. As mentioned in a previous post, the actual load current on a single 7.2V Prius module is about 1//2 of what these testers drain from a standard lead-acid 12V car battery.
  14. gdanner
    gdanner Member
    134
    51
    Central Illinois
    I recently learned about the Tenergy T180.
    It's an updated version of the popular B6-AC style of single-channel "RC hobbyist" charger/discharger. Many vendors still offer the basic generic B6-AC for about $30 USD. In contrast the Tenergy T180 is $99 USD. But it does have several additional features which intrigue me.
    I've had a B6-AC for years. It's OK for charging Prius modules but its discharge current is very limited and it doesn't really give me all the information I want.
    Does anyone here have experience or comments about the Tenergy T180?
    Tenergy T180 100W Balance charger with touch screen_metal housing
  15. PriusTech
    247
    105
    Reno
    I bought 4 of them, they were $75 ea. on Amazon, with a bunch of used core modules I need to find all the good/bad ones before grid charging. The T180 saves the peak amp hours readings from a charge/discharge cycle. I have 68 modules and was able to test 28 of them at 5500 mAh or higher, half of them were 4500-5000, they date code around 2008
    This YouTube guy covers it pretty well
    #75 PriusTech, Aug 26, 2025
    gdanner likes this.
  16. hurricos
    hurricos Junior Member
    55
    Burlington, Vermont
    You can slap one together for ~$1000 and a few hours work, but you'll notably only get channel voltages, not module voltages.
    1) GitHub - hakanrolsson/PriusGen2BatteryMonitor: This project monitors Toyota Prius Gen2 Battery ECU&#39;s using dual CAN buses
    2) Gen2 Prius or Gen3 Prius OpenInverter board, installed in an inverter.
    3) A dump load; preferably, another HV battery, attached to the boosted bus of the inverter.
    4) (hand-waving) some electronics to drive the pre-charge contactor and main contactor; IIRC the HV ECU usually does this, not the Battery ECU.
    At that point, all you need to do is to communicate with the 328p controlling the Prius inverter buck-boost stage, driving current out of (or into) the NiMH battery.
    gdanner likes this.
  17. gdanner
    gdanner Member
    134
    51
    Central Illinois
    Thanks! I am ordering one right now.
    This will double my charging capacity since I already have a B6AC charger. I bought it years ago.
    Actually the T180 will more than double my battery testing speed because it has useful features which the old B6AC lacks.
  18. gdanner
    gdanner Member
    134
    51
    Central Illinois
    As soon as the T180 arrives I'll be able to finish balancing my HV battery.
    I'll be combining 4 used replacement modules (fully tested by me) along with the 24 existing modules which are still all in good condition. Previously I've only had one charger (my B6AC). Adding the T180 will speed things up.
    I already have several of these "DC electronic load" devices for discharge testing:
    http://en.atorch.cn/upload/20241224153104.pdf
    • The "Atorch DL24" is one of the better devices of this type among many. There are many vendors offering similar units for a wide range of different prices. Some of them don't work at all. But the DL24 has been very useful for me. Note: the DL24 does not have any charging or cycling capability.
    My goal is to have my Prius running by the weekend.
    #78 gdanner, Aug 26, 2025
  19. gdanner
    gdanner Member
    134
    51
    Central Illinois
    My Tenergy T180 arrived yesterday. I've been using it ever since.
    One operational difference I observed so far is that "charge termination" by -dV/dt is more sensitive on the T180 when compared to my old SkyRC imax B6AC V2 (Note: This is a genuine SkyRC unit, not a generic imitation.)
    I haven't yet connected the T180 to a Prius module.
    But I have been testing the T180 with several NiMH tool battery packs which have cells in the range of 2,000 to 3,000 mAh inside them. Some of my test packs are several years old. I'm very familiar with their performance and capacity. Several of these packs are 14.4V (12S), the same voltage as a pair of Prius modules in series. I also have a couple of 19.2V (16S) NiMH packs which can be charged with the T180, but not with the B6AC, which tops out at 15S for NiMH or NiCd.
    When I charge a 2,000mAh pack at 1A with a -5mV/cell -dVdt on the old B6AC, the battery pack temperature rises substantially over the final 10-15 minutes of charging. Perhaps 10 to 20 degrees F.
    In comparison the T180 terminates charge without appreciably raising the temperature of the battery pack while using the exact same setup parameters (1A charge rate, -5mVcell -dV/dt).
  20. gdanner
    gdanner Member
    134
    51
    Central Illinois
    I've been experimenting with a range of "top charge" voltages and also with "deep discharges" down to voltages in the range of 0.4 to 0.8V per cell.
    In both cases I am using very low currents when operating above and below normal cell voltages.
    A low current (5 to 50mA) "top charge" seems to be capable of raising the voltage of every cell in a pack up to "full charge." I'm getting voltages of 1.42 to 1.44V /cell with currents as low as 5 to 10mA. This corresponds to 8.52 to 8.64V for a single Prius module. I limit the duration of my top charging to 10 hours in order to avoid actual overcharging. At 10mA it takes 10 hours to apply 100mAh to a pack. Also, 10 hours is long enough to reach stable voltages within just a few mV of each other for every pack I've tested so far. My idea here is that this low-current "top charge" might be a suitable way to confirm that all cells in a series-connected pack with many cells are actually "balanced" with each other. Perhaps this method could be used to balance an entire Prius hybrid pack? Prius "grid chargers" may have similar characteristics.
    I've seen many discussions of success with "raising the mAh capacity of used cells" by "deep discharging" at a very low rate down to voltages substantially below the standard 1.0V per cell discharge cutoff limit. I'm experimenting with discharge currents in the range of 50mA up to 200mA. and with cutoff voltages of 0.8, 0.6, and 0.4V per cell. Interestingly all the packs I've tested so far are recovering to a normal open-circuit per cell voltage above 1.0V per cell within 5 to 10 minutes after ending a deep discharging cycle. This happens even when I take them down to 0.4V/cell.
