Custom Enginer PHEV (8kWh)
Discussion in 'Prius PHEV Plug-In Modifications' started by krousdb, Aug 29, 2009.
  1. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    Since these reports are looking the same every day, I will just post new record highs and tank results. I will also start recording tank data at CleanMPG.com.
    9/03/09 Morning Commute - New Record High
    Driving Conditions
    Dry.
    Ambient Temp = 61F
    Winds = 10 MPH Tailwind :D
    Windows Closed
    Fan set to level 2, no AC.
    Results
    Trip ScanGauge MPG = 121:eek:
    Current Tank = 448 Miles
    Tank ScanGauge MPG = 94.4
    Tank MFD MPG = 94.0
    Analysis
    Using feedback from the ScanGauge to help me improve my results.
    PHEV Performance
    67.3% Improvement in Fuel Economy
    40.2% Reduction in Fuel Use
    2 people like this.
  2. eMileage
    eMileage Member
    33
    38
    Toronto, Ontario, Canada
    Thanks for the update! Congrats on your new high score! :rockon:
    I may have missed it, but if not, can you elaborate a little on which ScanGuage feedback you are monitoring and how you are using it to improve your results? Thx.
    2 people like this.
  3. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    I think thats probably a good plan. Use the two chargers to get through the bulk/fast charge phase, then shut one off and let the other do its funny little dance until charge is full. It would be great if there was a way to rig one of the chargers to turn off automatically at the end of the bulk phase, but I guess that could still be problematic as you wouldn't be sure that charger would hit the end of bulk first.
  4. miscrms
    2,079
    526
    Phoenix, AZ
    I may have mentioned this before, but IMHO the improvement in performance of a PHEV should really be measured as reduction in fuel consumption rather than improvement in MPG. You are generally going to drive a given distance (like your commute) and what you are striving to do is reduce the amount of gasoline burned to make that trip. So it seems like the amount of gas saved is the relevant measure. As has been mentioned in numerous threads on PC most of the world measures fuel economy this way, in units like litres/100km rather than km/litre
    For the most recent example: 121 vs. 72.3MPG is a 67.3% improvement in MPGs, but the amount of fuel burned is reduced by (1/72.3 - 1/121)/(1/72.3) = 40.2%. Still a great result, but more indicative of your actual fuel savings.
    Rob
    3 people like this.
  5. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    Math is fun... if you only have your % delta, a quicker calc is [(1+ 0.673) ** (-1) ] - 1 = -0.402 or 40.2 % reduction.
    2 people like this.
  6. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    Updated last report to include 40.2% reduction in fuel useage.
    2 people like this.
  7. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    Currently researching Can View. I can't stand not knowing what is going on! Can someone tell me all of the good things Can View has to offer? What are the drawbacks?
    2 people like this.
  8. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    I guess some of the CAN messages changed from 2004 to 2005. I can't figure why you don't see "gps" or "cdl" or "ccl". All of those should work. The only thing I haven't been able to put on XGauge is MG1 rpm.
    But, Can-View is infinitely more verbose and for 2004, I think it displays right on the MFD :rockon:. Here's the parameter list of what it's programmed to monitor:
    http://www.hybridinterfaces.ca/disppars.html
    11011011
    2 people like this.
  9. mrbigh
    3,686
    699
    Long Island, NY
    For a 2005 Prius, no draw backs. The information can be displayed
    in the MFD directly with CAN-view 3+. CAN-view is the equipment with more displayed information from the CAN through the OBDII for a Hybrid vehicle.
    I own a 2004 and choose to have Ver 4+ with an external touch screen monitor and I installed it "in" the dashboard, behind the steering wheel.
  10. atfsi
    atfsi New Member
    91
    96
    47
    Now THAT is neat ! Where did the panel come from ? 2010 available ?
  11. mrbigh
    3,686
    699
    Long Island, NY
    It is a handcrafted piece with a lot of patience and dedication.
    2 people like this.
  12. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    I don't think CanView has been ported to 2010 Gen III yet... sorry.
    11011011
    2 people like this.
  13. miscrms
    2,079
    526
    Phoenix, AZ
    I have neither, so can only comment on what I've read. CAN View is a product that was specifically developed to monitor the internal goings on inside the Prius. Norm was a pretty early pioneer in deciphering the Prius CAN data, and it seems like there are still things he has figured out that no one else really has. It allows you to monitor a lot more parameters than the Scan Gauge, and to see a lot more of these all at once and in different formats. As someone mentioned the V3+ for the '04-'05 displays data right on the MFD and gets feedback from the touchscreen. It acts like another "page" just like the consumption, energy, or HVAC screens, and still lets you use the screen for all its intended purposes. The display is fairly customizable and has multiple pages that you can setup. The graphics are pretty 1980s, as this is all running on a micro-controller not a full blown PC, which is probably just as well from a robustness/stability standpoint.
    In addition to displaying CAN parameters, the CAN-View has a number of on-board relays that can be configured to open or close based on the values of various CAN parameters. This controller was developed independently, but became the primary controller for the Cal-Cars open source project until they moved on to their own CAN spoofing controller. The CAN-View is a listening only device, it does not put any data out on the CAN bus. The website is a little tricky to navigate, but there is a lot of good info hiding in there :)
    CAN-view index
    I'd say its only real downside is cost, for those who don't have a PHEV conversion and just want a little more visibility into whats going on inside a Scan Gauge is probably almost as effective for less money. On '06 and up cars you also need to mount an external touch screen. For those that want to see in more depth what their car is up to, or be able to monitor more parameters at once, or be able to trigger relays based on CAN data it seems like the CAN-View gives you a lot of extra functionality for the extra money.
    Rob
    2 people like this.
  14. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    No question CanView rocks, I think their product is top notch. For those on a budget, here's an opensource CanScan port. I know that Ken also has a Can Product that may still be in "Beta Test Freeware" phase. I think all of these require a CAN232 or CANUSB fob which cost $100+. The ScanGauge only gives you 4 gauges, but here's a list of [post="950412"]Prius 2007 Gen II Specific[/post] data it can report. It can also do most all the Standard ODBII stuff too.
    There are options, but they all start around $110 and move up from there.
    11011011
    2 people like this.
  15. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    So I got a MIL today. :eek: First one in the 500+ miles I have on the kit. So I'm thinking to myself, what did I do differently today?
    Normally, in an effort to get a bit more range, at the end of my drive home, I would force EV to bring my OEM pack down to about 50% SoC. Then, that evening after a few hours of charging, I would boot up, while charging, and fire up the converters until the Soc got up to about 75%. Then power down the converters and the car. But each morning, I would notice something funny. The Soc was at 75% where I left it but the voltage, instead of being 238 or so was at 205-210. The two values were obviously out of whack. Then, a few miles into my drive I would notice something like a recal event, forcing lots of current to the MG and bringing the SoC down to 60%. At that point, the voltage is back at 220 and all functions go back to normal. No MIL however.
    So that happened Monday, Tuesday, Wednesday and Thursday. But today, I did something different. I forgot to charge up my OEM pack last night so I did it this morning, just before leaving. What I did not do was power down. When I left, instead of seeing a high Soc and low Voltage, I saw 75%Soc and 238V. Just when I got the place when the recal usually starts, I got the MIL and engine racing. I pulled over and saw that SoC on the SG showed 92%. I cleared the code, powered down and booted back up again. Now the SOC showed 60% and the voltage was back down to 220.
    Obviously, my attempt to squeeze out more range using the OEM pack is not a good idea. :p
    I received the second charger and third converter today, but I won't be able to get anything done on this holiday weekend. Monday night, the charge routine will not include the OEM pack. Hopefully Tuesday will be MIL free.:cool:
    2 people like this.
  16. Flying White Dutchman
    4,376
    313
    MIL... did you get a DTC?
    what happend is that your prius is trying to keep the SOC around 60% max 75%
    because it noticed 92% its using the ICE to get rid of the energy....
    but i guess you already know this.
    2 people like this.
  17. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    I cleared the code without recording it. I don't think the SOC was actually 92%, but rather the ecu was confused and didnt know for sure so it did the safe thing and dumped what it thought was excess energy.
    2 people like this.
  18. mrbigh
    3,686
    699
    Long Island, NY
    I guess that you experiment only once..............be careful.;)
  19. Flying White Dutchman
    4,376
    313
    that is indeed a nice setup
    some hard work went into making that i bet.
  20. NWPriusPlus
    NWPriusPlus Junior Member
    Pacific Northwest
    Thanks for all the great info you are providing on the Enginer System. It is a great service to the PHEV community.
    I think your decision not charge the OEM pack is correct, at least for now. I would like to emphasize for all PHEV drivers who are charging their OEM hv battery packs (as the Enginer system can do, both while driving and while in Park) to be especially careful regarding battery temperatures, including what can happen after the car is shut down. As you may be aware, there have been several Prius hv battery failures in the PHEV community over the years as people have attempted to charge without monitoring the temperatures properly.
    Based on having charged my 3 Prius NiMh packs several hundred times (see One Year of Driving Our BMS+ Plug-In Prius), it looks to me like your NiMh pack may have reached sufficiently high temperatures to have been rapidly self-discharging overnight (although 205v seems a long way down). It is unlikely that any damage has occurred, but by driving in EV and PHEV modes before charging--especially if combined with high ambient temps--it is possible that your OEM NiMh pack may have been warmer than desirable for starting a charge. Also, 238v is getting right up near the top of the range.
    Does your instrumentation allow you to monitor your Prius battery pack temperature before, during, and after charging? As you know, the Prius pack is a relatively large mass of NiMh in a very tightly enclosed space, with very little surface area for releasing heat unless it has a strong fan-forced circulation. ANY charging rate (from a few hundred milliamps up to several 10's of amps) that either starts with the battery at a high temperature or goes on long enough will eventually result in increasing temperatures. As I understand it, this can lead to a high rate of self discharge as the oxygen evolved at positive electrode diffuses to the negative electrode and combines with the hydrogen stored there, producing more heat and intensifying the reaction. The voltage level can fall dramatically it the temperatures stay high for many hours.
    Without knowing the accuracy of your SOC, voltage, and temperature data, it is not possible to be sure that this is what has occurred. Even a simple digital thermometer probe slipped in through one of the holes in the top of the sheet metal Prius battery case will tell you a great deal (not as good as a probe placed into one of the thermal wells built into the Prius modules, but that requires opening up the main case...)
    When the car is in ready mode, the battery ecu will report temperatures from its 3 probes, and these messages are visible on the CAN bus (and on CAN-View). Based on these temps, the Toyota fan will run at low (96f), medium (107f) or high (122f), and on full there is a tremendous airflow. But when the car is shut down, no cooling is available without some sort of modification.
    A lot more information about charging the Prius NiMh packs can be found on various pages on Norm's site (hybridinterfaces.ca). By the way, I think the CAN-View system for monitoring any PHEV conversion is worth every penny and then some. I offers an astounding amount of data, including a RAW page that lists all of the CAN bus traffic!
    Personally, I prefer not to charge if any of my NiMh packs are over 90f--I just wait till late at night or very early morning when the air in the garage has cooled enough, and then run my battery fans for a while before charging. Living in a mild climate makes this easy. I also find that it is preferable not to charge past 232v or so the night before (Panasonic states that their prismatic cells do not self-discharge when kept below 70% SOC), and instead top up to full (236v to 238v) right before discharging by starting to drive in EV mode, which obviously prevents any self-discharge.
    Thanks again for the wealth of innovations and data you have made available.
    NW BMS+ Driver
    LeeD, atfsi, eMileage and 1 other person like this.
