Custom sub box a success!
Discussion in 'Gen 2 Prius Audio and Electronics' started by audiodave, Mar 14, 2017.
  1. audiodave
    audiodave Active Member
    800
    272
    US
    Weedle, Rocinante, TGrracie and 3 others like this.
  2. dolj
    dolj Senior Member
    8,622
    4,376
    Wellington, New Zealand
    Nice. Good work!
  3. DanGiant
    DanGiant Junior Member
    Bremerton
  4. audiodave
    800
    272
    US
    I had a guy in the LA area make it for me. You can find him on Ebay. Just search the car and subwoofer enclosure. It's fiberglass made to the shape of the hole.
    But I did beef it up, glass was to thin in areas for a subwoofer.
  5. audiodave
    800
    272
    US
  6. audiodave
    800
    272
    US
    Gear isn't wired up at that point. Love this compartment for the equipment!
  7. Malosos
    Malosos Member
    117
    33
    Los Angeles
    I'm in LA, how much did that set you back?
  8. audiodave
    800
    272
    US
    The fiberglass enclosure was basically 300. But you need to trim the panels a little on your car to fit.
    Malosos likes this.
  9. Malosos
    Malosos Member
    117
    33
    Los Angeles
    cool thanks
  10. atari101
    atari101 New Member
    US
    Anyone have luck finding this seller? I can't find anything under eBay search.
    Thanks
  11. audiodave
    800
    272
    US
    The sub enclosure guy? Search custom sub box Toyota Prius.
  12. audiodave
    800
    272
    US
  13. tannerpace
    tannerpace Junior Member
    42
    charleston
    How did your car hold up with all those amps? What was the total rms? Did you get a different 12v battery? Run. Capacitor? I'm asking because I'm thinking of installing a 500 watt rms sub amp.
  14. audiodave
    800
    272
    US
    I have a Alpine 5 channel class D amp to run everything. It's 100 by 4, and 4-500 for the sub. I replaced the 12 volt with a optima. Works great sounds excellent. Not capacitor. I don't run it much without the car on but otherwise I don't have any issues.
  15. Mohsin Afzal
    Mohsin Afzal Junior Member
    24
    Burnley
    ----UK----
    Hi.. just wanted to ask how you were getting on with your install and whether you have had any issues running this setup. I was wanting to put in a 500 rms amp and sub into my Prius. But was worried if I would effect the hybrid system and also if the standard battery can hold up to the amp using its power. Also could you also put a link or model number of the Optima battery and your amp.. kind regards
    #15 Mohsin Afzal, Aug 3, 2019
  16. Cityhunt3r
    Cityhunt3r Junior Member
    2013 Prius Plug-in
    I also would like to know...
