Custom subwoofer box build.
Discussion in 'Gen 2 Prius Audio and Electronics' started by Gun owning Prius driver, Dec 16, 2012.
  1. Gun owning Prius driver
    397
    78
    Downey, California (Los Angeles Area)
    At work bores decided to turn it up a bit amps need to be tuned.
  2. Gun owning Prius driver
    397
    78
  3. Robert Meserole
    Robert Meserole Junior Member
    Have you made any more progress? I would like to see where this is going. I have 2 sa-8 in fiberglass enclosures behind the wheel wells. I threw them in a junk particle board "sealed" box and they sounded louder. I'm in the process of designing a ported box but don't want to give up all my boot space either.
    So how or is it possible to load anything in back? How do you protect the subs and still have any functionality?
  4. Gun owning Prius driver
    397
    78
    Hey what's up well I wasn't really thinking when I came up with this design lol loading stuff is a pain but dam does it sound good. I will be re building the box the floor will consist of amps with plexi glass on top, the subs will be move behind the seat almost to create an L shape box
  5. Gun owning Prius driver
    397
    78
    Hey guys custom subwoofer box for sale 150 obo moving away forces sale :(
  6. johnnyP13
    johnnyP13 New Member
    do you have that running off a reg 12v battery? and everything stock with just the sub? and amp?
    thanks
  7. Gun owning Prius driver
    397
    78
    I have two 12v, two amps.
  8. Gun owning Prius driver
    397
    78
    After market head unit and speakers
  9. johnnyP13
    is it worth it? to upgrade the head unit or you think i could run 2 amps 1 2channel amp 300w rms and 1500w rms for my sub and new front speakers with a upgraded 12v or do i need 2? thanks in advance
  10. Gun owning Prius driver
    397
    78
    I think one battery should be more than sufficient. I'm running a mono channel and a 4 channel. As far as head unit def get aftermarket.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Big charging load the Inverter was not designed to handle. And that ain't no $200 200 amp alternator. Inverters are very expensive. Hope your maintaining the Inverter coolant.
    Mpg will get hammered and they are 2 different manufacturer batteries so one will have a difference in life and impedance so one will always be charging and the other supplying when the car is sitting. Its a good idea to install a battery tender in your set up and always be tending when you park the car for the night.
    I would at least put a 100 amp fuse between your parallel batteries so if one gets a shorted cell you at least won't have a cabin fire.
  12. johnnyP13
    Ok but how much will my mpg get hammered by?
  13. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Based on reports here by posters with bad 12 volts quite a bit. Maybe now running at 35-40 mpg's. Whats the consumption meter say?
    I use bad 12 volt as an example because you now have twice the charging load on the Inverter. But will be interesting to see how the Inverter likes that.
  14. johnnyP13
    So after your install nothing has gone wrong it drives and operates jsut like you got it before you put in all the stuff? and did you do the wire all yourself or had some one professional install it?
    Thanks,
  15. Gun owning Prius driver
    397
    78
    Had it professionally done I did add a fuse between the two. As far as mpg I didn't suffer anything and I have 17's on mine also. Just went on a road trip to midland Texas got roughly 41-45 mpg all the way. Which for my driving is good lol
  16. Gun owning Prius driver
    397
    78
    Now I'm not saying the other guy is wrong, but as far as my experience doing this build have been real good. I also upgraded all my grounds to 0 gauge
  17. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    I had the same issue...thought it was my 12v...but later found out 2-3 tanks later, it was just bad batch of gas.
  18. edthefox5
    10,096
    4,833
    Clearwater, Florida
    41-45 is not bad considering very big 12 v charging load with the amp pounding and 2 somewhat dissimilar batteries in parallel. Most stereo peeps running 2 batteries upgrade to a 200 amp or more alternator. You of course cannot do that.
    Do the MFD 12 volt diagnostic and see what the charging voltage is in ignition:
    Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
    Time will tell. Since your into electronics I would monitor the Inverter temp though to see how unhappy its getting. Go to home Depot or eBay and buy an IR Thermometer and measure the inverter Coolant reservoir and Invert case.
    There is a temp monitor in that circuit but its very poor. By the time it throws an overheat DTC its way past overheat. And then the INverter crowbars and shuts off. Same symptoms as a failed Inverter coolant pump.
    My point is you will never know how hot the Inverter is getting unless you do my test. And I'm curious also.
    Should be around 100F with a heat soak after shut down of about 130F.
  19. Gun owning Prius driver
    397
    78
  20. R-P
    R-P Active Member
    804
    288
    Netherlands
    As in the battery ground (easy) and inverterground (I'm not touching that :ROFLMAO: )?
