Customer Support Prog ZHB Halogen bulbs
Discussion in 'Gen 3 Prius Audio and Electronics' started by Terrell, Nov 29, 2017.
  1. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Toyota sent owners of the 2010-2011 Prius a letter saying there have been a number of reports regarding the halogen low beam headlamps lifetime is shorter than expected, and Toyota is offering to install voltage adjustment wire harnesses and replace both low beam headlamp bulbs.
    My H11 bulbs seem to burn out more often than any other car I've owned, and I replace them at least annually. I called the dealership, and one of the service guys told me most customers need new bulbs every two years.
    Has anyone had this service done? (Install voltage adjustment wire harnesses and the bulbs.) If so:
    Has it caused your low beams to be dimmer? I would guess so.
    My guess is that since I run the low beams as running lights for safety, they just burn out more frequently than "normal."
    At night, I want as much light as possible, so if the wire harness makes the headlamps dimmer, then I'd rather replace them annually.
    Thoughts? Experience?
    wrydere likes this.
  2. wrydere
    wrydere Junior Member
    I am currently waiting for the parts to be ordered and will be getting the new wire harnesses installed within a week or so.
    The low beam bulbs in my 2010 Prius typically burn out once per year, always one before the other, and sometimes they have burned out in as little as 2 or 3 months after installing new ones. My car, I believe, is a textbook example of this wiring harness defect.
    For comparison, I don't think I ever replaced a bulb in my wife's 2008 Prius, which she had for six years.
    I don't think the voltage adjustment will noticeably dim the lights, but simply keep them from burning out due to fluctuating voltages.
    After all the evenings spent replacing bulbs in Autozone parking lots before a long commute home from work – and darn are they annoying to access in that compact engine compartment – I am quite happy that Toyota is finally addressing the issue, I just wish it had happened sooner.
  3. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    I've changed them so often I can now do the left one in less than 60 seconds (it takes longer to open the package!), but the right side takes me maybe five minutes to jamb my hand in and twist the bulb out - the wires are too tight - I install the right bulb without the wires first, then connect them after the bulb is seated.
  4. wrydere
    Yeah, the passenger side one is tricky. I find that if you remove the bolt holding the air intake, you can pull the air intake upright and give yourself an extra few inches of space, which makes it much easier. I eventually started carrying the appropriately sized socket for that bolt in my glove box at all times.
    xliderider likes this.
  5. LibrarySue
    LibrarySue Junior Member
    Raleigh NC
    Ahhh, but less than a week after getting my letter, my Prius electrical system started acting weird. Then the battery died and I had to get it jumped. I'm wondering if this harness problem could be messing with my alternator.
    #5 LibrarySue, Dec 20, 2017
  6. bisco
    52,876
    i wouldn't be surprised.
  7. padroo
    padroo Senior Member
    2,763
    2,253
    Prius does not have a traditional alternator.
    The Prius uses a DC to DC converter located under the inverter under the hood.
    #7 padroo, Dec 24, 2017
  8. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    My 2010 passenger side low beam was still original when I received this notice, so it lasted 8.5 years. The driver side has been replaced 3 times, with the last 2 having lasted less than a year. I had the wiring harnesses replaced today, and of course they replaced both bulbs. I did not notice any difference in brightness tonight. The service adviser said they had to perform their diagnostics before they could replace the bulbs and harnesses. After the work was done, I asked what the diagnostics involved and was told there was really nothing, they just replaced it on my report of shortened life of the last 2 bulbs. Hopefully this is the end of this issue.
  9. kevelev
    kevelev Junior Member
    65
    ny
    So I've had my dealer do this service and they didn't charge me anything. Before I even had a bulb go out I was thinking of replacing the bulbs with aftermarkets because I think it's really hard to see at night. Has anyone done this since getting the "voltage adjustment wire harnesses"?
  10. LibrarySue
    Raleigh NC
    I have no memory of this recall whatsoever...I don't know if I got that work done on my Prius or not. I remember the battery. Anyway,
    In July of 2018, someone had a heart attack in a parking lot and parked his car on top of my Prius. So I bought another one. And just had ZHB recall work done!
    AzWxGuy likes this.
  11. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Today (after all this time) I finally had the ZHB service performed, because I got tired of replacing the bulbs so often. (I probably spent over $300 over the years on new headlamp bulbs since buying the car.) The ZHB service is a free service listed at 2.9 hours. It took the dealer around 2 hours, because they need to install a "wiring harness" - it looks like they added some sort of resistor to slightly lower the voltage to the headlamps and wrapped the wires. They also installed new bulbs. So far I've not noticed that the headlights are dimmer, but they must be.
  12. ChapmanF
    19,041
    By my measurements, it shaves about 0.55 volts off at the bulb, ending up a lot closer to an H11's rated voltage of 12.8. Because visible light output roughly follows voltage to the power 3.1 to 3.4 (closer to voltage squared is what you would think at first from Ohm's law, but higher output also shifts more into the visible region, hence the 3.1 to 3.4), this drop might shave 12% off the light output.
    But longevity follows voltage to around the power −13 to −16 (!), so the same voltage reduction could roughly double the life of the bulb.
    AzWxGuy likes this.
  13. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    I had the dealer warranty enhancement work done Feb 2018 and replacement bulbs continue to be functional. I had a headlight lens restoration done earlier, August 2017, which helped considerably with the quality and brightness of the beam. From where I sit in the car, I'm basically looking right down the headlight beam. So objects in the road are highly visible even on low beam. The halogen bulbs are a slightly yellowish cast anyway, compared to HID or LED. Hard to tell if the brightness has been reduced.
