Cutting the Cost: GM may take a hit on the price of hybrid systems to sell more units
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by cwerdna, Jul 11, 2007.
  1. Jonnycat26
    Jonnycat26 New Member
    1,748
    New Brunswick, NJ
    <div class='quotetop'>QUOTE(john1701a @ Jul 11 2007, 10:14 PM) [snapback]477263[/snapback]</div>
    John -- Fact is, Toyota set a goal of 50K units the first year. They barely sold 38K. That's a pretty large margin to miss a sales goal by. Spin it all you want, those were their goals, and they didn't make them.
  2. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    It seems to me that there is probably about 100 things they could do to a truck to improce FE before making it a hybrid.
    a short list
    better stock spark plugs and wires
    reduce the weight
    lower vehicle closer to the ground and have an adjustable suspension that can raise it for hauling loads and towing like a semi
    make the more efficient 6 speed automatic standard in all vehicles
    just to name a few
  3. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    <div class='quotetop'>QUOTE(Jonnycat26 @ Jul 11 2007, 09:35 PM) [snapback]477282[/snapback]</div>
    Refusing to look back beyond the year of production itself won't change the facts.
    The year *BEFORE* then, those nasty misconceptions about hybrid speed & power were crippling the rollout efforts. Sadly, there were quite a number of people intentionally misleading. Attempts to convince those new to the technology that a "full" hybrid could never be fast or large were a common problem.
    Those goals were achieved, an undeniable success... well proven by the rollout of even faster & larger "full" hybrids later.
    The fact that an additional goal of selling them at a profit wasn't met, but the goal to getting 50,000 of them in the hands of consumers still was.
    That's 3 out of 4.
  4. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    They could sell a good number at $5000 if there was a tax credit. More then that and it will be hard to sell. GM does have room to sell the hybrid at a 'loss' because GM makes up to $10,000 or more profit on large SUV's. They will not loose money on a large SUV even if they took a $5000 hit on the hybrid option.
    GM's dual mode system is more complex then I would like. The Prius system while advanced is actually wonderfully simple mechanically. Most of the complexity is in the software and the controller which once perfected it does not add much chance of failure. The GM system has alot of parts to fail, two clutches for example. I almost like the BAS system more for GM because I don't fear it breaking as much and it could be cheaply added to so many vehicles. For the consumer it has a quick payback with any subsidy.
  5. Godiva
    Godiva AmeriKan Citizen
    10,339
    So what? Look at them now.
    It's better to set an ambitious goal and not meet it than to set a safe goal and then coast once it is reached.
    In fact, a goal should never be reached. As you approach it, it should be reset farther away.
  6. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    <div class='quotetop'>QUOTE(Jonnycat26 @ Jul 11 2007, 10:35 PM) [snapback]477282[/snapback]</div>
    You will have to show me that reference. I've been selling them since they debuted and I never hear that the HH was intended to sell 1/3 of the annual volume?
    I'll leave your statement in abeyance because I might have missed something but I'm waiting for some facts in support of it.
  7. bulldog
    bulldog Member
    224
    CA
    <div class='quotetop'>QUOTE(Jonnycat26 @ Jul 11 2007, 07:35 PM) [snapback]477282[/snapback]</div>
    Can you please supply referenes to this. Not sure why Toyota would set a sales goal of nearly 45% (OK, 50k out of 130K or so) of a model to be hybrid.
  8. DeadPhish
    2,010
    353
    Multiple misunderstandings due to lack of in depth reading...Here is the actual link to which you referred.
    http://www.detnews.com/2005/autosinsider/0...utos-125088.htm
    From the Detroit News:
    Now here are the actual results for 2005 from Toyota's website:
    http://www.pressroom.toyota.com/Releases/V...YT2006010484765
    The key figures are:
    20674 units - RX400h
    17989 units - HH
    38663 units - Total
    This was just the US, it doesn't include CA or AU or EU.
    Facts are your friends. It's OK to be accurate. They hit their goal, bet on it.
  9. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    <div class='quotetop'>QUOTE(hill @ Jul 11 2007, 11:31 AM) [snapback]476992[/snapback]</div>
    It actually $3000 on the 07 H2 and $2500 on 07 H3 per http://www.cars.com/go/advice/incentives/incentivesAll.jsp. For 06 versions, it's $6500 and $3500 respectively.
  10. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(Jonnycat26 @ Jul 11 2007, 01:29 PM) [snapback]477076[/snapback]</div>
    So... the idea is to sell at a loss and make it up on volume? Ah. Yup, I keep seeing GM "learning" while Toyota eats their lunch.
    As usual... I wonder why you ever bought a Toyota. Punushment for something you did in a past life?
  11. hill
    8,790
    <div class='quotetop'>QUOTE(Pinto Girl @ Jul 11 2007, 01:25 PM) [snapback]476930[/snapback]</div>
    Andy Frank (one of several who truly advanced the developement of the PHEV concept) and his research students build suburban type SUV plug in's, with enough EV range to work a 500% mileage increase for the average commuter. So I'm always filled with angst when I hear about 12% - 15% - 20% mpg improvements. When Toyota launched the Prius, it was an expensive and risky gamble, that ultimately paid off. So with battery / electric assist, we know we're on to something. Next logical sep would be PEHV's. Where are the financial risk takers now? ... especially if fossil fuel imports keep becoming increasinly more costly.
    <div class='quotetop'>QUOTE(darelldd @ Jul 12 2007, 03:20 AM) [snapback]477385[/snapback]</div>
    Nah, my guess is he just likes to take the opposite view, even when/if he doesn't believe it.
  12. Tideland Prius
    16,547
    <div class='quotetop'>QUOTE(hill @ Jul 12 2007, 09:45 AM) [snapback]477555[/snapback]</div>
    Exactly. When Toyota developed the Prius, their goal was to DOUBLE the FE of a Corolla-class vehicle. Not improve it by 20%. Originally, Toyota wanted a 50% improvement. Then they wanted a 100% improvement so the engineers looked to hybridisation for the answer.
  13. Jonnycat26
    1,748
    New Brunswick, NJ
    <div class='quotetop'>QUOTE(DeadPhish @ Jul 12 2007, 01:39 AM) [snapback]477360[/snapback]</div>
    Well, one of the articles I was referring to was here:
    http://www.theage.com.au/news/business/toy...3353208622.html
    Where a VP from Toyota JP said that the HiHy has not sold well in Japan, and Toyota needed to rethink their hybrid strategy.
    As for the other article, it's around here somewhere, I posted it a few years back. Toyota had a goal of 50K in NA... and sold 38 in NA.
  14. crypter
    crypter New Member
    49
    <div class='quotetop'>QUOTE(Jonnycat26 @ Jul 12 2007, 01:46 PM) [snapback]477697[/snapback]</div>
    So what if they only sold 38K as opposed to 50K their first year of the new model? Recently Toyota sold 17,756 hybrids - in a month! (June). Seems like they are taking a long-range view and it is paying off big time for them now :lol:
  15. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    <div class='quotetop'>QUOTE(Jonnycat26 @ Jul 12 2007, 03:46 PM) [snapback]477697[/snapback]</div>
    Not sure I'm following; what does a comment about "rethinking hybrid strategy in the US" from a Toyota VP for the JDM, have to do with hybrid sales in America? I'd suggest that our market isn't even part of this guy's bailiwick.
    As far as goals go, it's often prudent to redefine them in light of additional information. No one even knew *who* an American hybrid buyer even was, a few short years ago. This isn't like selling a new model of a existing nameplate to repeat buyers; I think that's an important fact to remember.
    I'm not smelling failure anywhere near Toyota's hybrid program, no matter how it's spun. Selling hybrids to Americans is, indeed, quite untried; I'd suggest that there is precious little previous data to base any firm "predictions."
    Toyota has successfully created a brand name, using only a slightly odd looking (in a good way!) and totally unique (to this market) automobile. I'll bet that just about everyone knows what a Prius is; it's even a Monopoly piece for goodness sake!
    Meanwhile, Ford still is struggling with renaming the Five Hundred. I'm a bit slow today; tell me again, where's the problem?
  16. DeadPhish
    2,010
    353
    <div class='quotetop'>QUOTE(Jonnycat26 @ Jul 12 2007, 04:46 PM) [snapback]477697[/snapback]</div>
    I found the article for you, posted above. It was 52,000 units to be exported from Japan in 2005, including US, CA, AU and EU. The entire US allocation was sold at 38K+.
  17. bulldog
    bulldog Member
    224
    CA
    Seems like you are wrong again. Harrier and Kluger does not sound like Highlander to me. As well as the fact that it was for all exported hybrid SUVs from Japan. Very different picture than what you wanted to portray.
    I have noticed a number of your posts where you keep on ragging on Toyota with incorrect information here. Like the Aura Hybrid that will have similar MPG than the Camry hybrid.
    http://priuschat.com/index.php?s=&show...st&p=300290
    Yet Aura gives 24 city, 32 highway and 27 combined
    Camry 33 city, 34 highway and 34 combined.
    Both on new EPA scale. See Fueleconomy.gov
    Further claiming Vue hybrid gets better milage than Highlander hybrid
    yet Vue = 23, 29, 26 vs HiHy 28, 25, 26 thus even for a much more powerful vehicle (HiHy), much less pollution (again check above mentioned site) and larger (edmunds). Only with a price differnce of 10K not 13K as you mentioned. Or were you trying the normal GM trick of comparing a FWD GM to AWD Toyota.
    Also when you say the Malibu hybrid gets 40 highway and 29 city, please provide the tested numbers ( I haven't seen any).
    http://priuschat.com/index.php?showtopic=2...mp;#entry302252
    So in short, why not just get Aura and move on? And while you are at it, quit trying to quote incorrect numbers like all you GM fanboys seem to do. Toyota has their shortcomings, but comapred to GM :rolleyes:
    I wish GM would spend the same effort and resource in their engineering department as they do in their misinformation department. If they did, they would be in much better shape. I see Ford turning around long before GM, as they are hitting the nail on the head with a number of products in the last few years.
  18. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    There is a big change coming. A small increase in gas prices (yes-small in hindsight 5 years from now) causes a big surge in Prius sales. Apparently, GM thinks that this means everyone wants hybrids when gas prices go up, and that absolute MPG is of lesser importance. I did not buy the Prius because it was a hybrid. I bought it because of 52 mpg.
    What is actually impressive is the following:
    1) Toyota, at the urging of Eiji Toyoda, starts work on a high mileage car during the huge SUV boom. Not as an R&D project, but as a 1000 per month production project. This was not some "marketing" result, but the result of someone very high up thinking realistically.
    2) A bunch of independent groups are doing a lot to develop an PHEV to make up for the void of no car manufacturer (including Toyota) providing anything. They know that the demand is there, just not the vehicles. They have demonstrated the concept by doing it. They lead, others follow.
    3) A fully electric car startup, Tesla, has sold everything they have available before it is built....and is making a big manufacturing plant. Small number of very smart innovators.
    A very small number of individuals is making a very big difference. GM does not appear to be making a difference.
  19. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    <div class='quotetop'>QUOTE(bulldog @ Jul 12 2007, 09:03 PM) [snapback]477928[/snapback]</div>
    (Surprisingly, I'm partly defending Jonnycat26 here.) The Harrier is the JDM version of the Lexus RX SUV. The Kluger is the Australian and JDM version of the Highlander.
  20. C.RICKEY HIROSE
    210
    S.F. BAY AREA CALIFORNIA
    <div class='quotetop'>QUOTE(Jonnycat26 @ Jul 11 2007, 03:29 PM) [snapback]477076[/snapback]</div>
    'disastrous' and Toyota's blunder.?
    Toyota announced that the HH accounted for 30% of all Highlander sale.
    When Toyota can sell 30% worth of HH among all Highlander sold, how can this
    number be _disastrous_ ?
