CV axle replacement. New non OEM. Wide turn bad noise
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Uberfast, May 7, 2021.
  1. Uberfast
    Uberfast Junior Member
    76
    Oakland , ca
    2014 Prius v wagon
    2014 prius v.
    New CV axle replacement. Non oem. Cardone brand. Right and left.
    Replace ball joints, and lower control arms.
    Seated 177 ft.lbs. No leaks. In forward and reverse no sounds. High an low speeds. No sounds.
    I make a wide turn and hear knocking grinding noise. Can feel the noise in the steering.
    What did I do wrong?
    Faulty part?
    I wish I lived on Endor
  2. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    What is the miles on the car? Are the wheel bearings in good shape?
  3. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    200,000 miles.
    Yes wheel bearings are fine
  4. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    Dust shield rubbing on the back of the brake rotor?
  5. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    No dust Sheild problems, all metal is away from rotors
  6. privilege
    privilege Active Member
    659
    169
    Birmingham
    I would expect more noise from a tight turn, than a wide turn...
    check your lug nuts and brake dust shield
  7. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    Rear hubs check out fine as well?
  8. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    Rear hubs are ok
  9. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    Is the noise the same on left and right turns?
  10. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    Yes same on both turns
  11. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    Can you record the noise and upload it?
  12. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    Yes, but I'm with mom. So tomorrow.
    Also I can feel the CV axle grind in the wheel as I turn. This only happens on a while tight turn as far as the steering wheel can go. The
  13. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    Wide right turn
  14. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    The company is sending me new axles
  15. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    Hopefully the new axles solve the issue. If not, record the noise and we will attempt to identify it.
  16. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    Thanks so much
  17. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    I want to share my thank yous to everyone who reached out to me on this thread. Thank you. I reinstalled the new axles. And everything is working well. Fingers crossed
    Tim Jones likes this.
  18. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    The issue was tie rods were backwards. I needed to switch the tie rods from left to right. The tire rim was grinding against the tie rod. The tie rod bows out. Thus the metal contact was happening on the wide turn
    cnc97 likes this.
  19. Mendel Leisk
    38,729
    No experience, but I’ve read drive shaft CV joint issues tend to be heard in ONE turn direction only. If you hear noise during right turn it’s problem with left driveshaft, and vice versa.
    Off-topic, but have you ever cleaned the Exhaust Gas Recirculation system, including intake manifold?
  20. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    Yes I have cleaned the exhaust Exhaust Gas Recirculation system, including intake manifold
