CV Half Shaft Woes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jsinclair92, Sep 28, 2018.
  1. jsinclair92
    jsinclair92 Junior Member
    22
    Jackson, TN
    My car is turning heads... and by gauging their expressions, they aren't admiring my ride.
    There has been a *click click click* noise going on for about a month. I can roll the window down and hear the noise bouncing off of nearby buildings, it's pretty loud.
    Yesterday, I put the car in neutral, jacked up the right side and spun the wheel and took the video below.
    Is there a good step by step guide with images to replace the cv joint? I have searched this forum and google as well, but have not found any.
    DLC82SV likes this.
  2. DLC82SV
    DLC82SV Member
    241
    119
  3. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I think you would need someone to help fix that stuff, if you're not a Diyer
  4. jsinclair92
    22
    Jackson, TN
    Sorry about the video, it should be working now.
    I'm an avid DIYer. I might have taken my vehicles to a mechanic once or twice in my life, for a weird electrical issue. I've never replaced a half shaft though, but I'm sure its nothing I couldn't tackle on a Saturday.
    Paul Schenck likes this.
  5. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    So, if you’ve got jack stands, a pry bar. A 1/2 breaker bar and a socket set you an do it. I had to add this socket to my collection IMG_5501.jpg
    You are going to need the instructions from a manual to follow though.
    iPhone ?
  6. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    K...and
  7. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    ...and you'd need a 30mm socket to loosened the but holding the CV head to the hub assembly.
  8. Paul Schenck
    524
    307
    Fresno, California
  9. valde3
    valde3 Senior Member
    2,002
    750
    Finland
  10. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    The factory service manual.
    https://techinfo.toyota.com/techInfoPortal/appmanager/t3/ti?_nfpb=true&_pageLabel=ti_home_what_is_tis_page
    $20 for a two business day subscription.
    This person found it necessary to convert the file format into PDF, to save a copy of the manual on his computer.
    Toyota TIS download tips | PriusChat
    Maybe you don't need to? Maybe there is an easier way?
