CV joint problems?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by lohikaarme, Oct 21, 2018.
  1. krmcg
    2,592
    2,393
    Whittier, CA
    Persistence pays off.
  2. b100
    b100 Member
    145
    75
    Netherlands
    Never tried that. Ill report back. But i think its ok.
  3. Lokii
    Lokii New Member
    Seattle
    Great work. I had the same issue on my Gen2. The noise was coming from the driver's side axle (inner joint). I used to hear the clicking noise when making a U-turn or any sharp left or right turns especially with slope involved. I replaced the axle by myself and the problem is gone. I just purchased an used part (43420-47020) for $50 (Pulled from 08, 67000mile Prius) from the local used parts shop. The shop showed me 5 other shafts of the same ID, but 2 of them already showing the "worn-out" sign, which is in this picture(The one on the left). If you are getting an used part, you never want a part like this (basically, the inner boot is fully extended, meaning the internal mechanism is being pushed out). When I pulled my original clicking axle, it was exactly like this.
    52,862
    oh my, that is a big issue. toyota should be called to the carpet and made to replace all 16 year old axle/cv joints
  5. ChapmanF
    19,027
    What pushes it out?
