CVT doesn't seem to shift?
Discussion in 'Gen 2 Prius Technical Discussion' started by Dody, Sep 2, 2012.
  1. Dody
    Dody Junior Member
    Eldon, IA
    2001 Prius
    Drove an 07 with 147K and engine seemed to be running at a higher rpm than normal
    compared to coventional transmission as though it was running in 1st gear. Anyone
    had this experience or know possible cause? THANKS
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    That's the way it sounds but its not really over reving. Its a planetary gear system and has no gear shifting.
    Normal. You really have to floor it to experience what your posting anyway.
  3. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    CVT's don't shift. Yeah, it's weird at first. The Prius is the second vehicle I've owned with a CVT. When you step on the go pedal, the engine sounds are definitely not "normal" ;)
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    I'm confused. Do you have an 01 Prius to compare with? That's what your profile says.
  5. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Hi Dody. It may just have been your expectations, or it may have been due to a low state of charge (SOC) of the Prius.
    Something I've found a little unusual about the Prius compared to a conventional car is that how "peppy" it is to drive tends to change with SOC. At low SOC you definitely notice the performance a little more sluggish and the engine working a bit harder. Usually this is only a temporary situation, but if the traction battery is faulty or badly weakened then it could be like that all the time.
    PriusGuy32 likes this.
  6. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    technically you can "shift" in the prius if you got a scangauge to see the rpm
    say you press the pedal (60% of throttle) rpms would say be like at 2500 rpm
    then when you reach your desired speed you lift ever so gentle lets say 40% throttle and rpms would drop to 2100 rpm (Instant FE will display this too... increasing mileage during the shift)
    there's your shift :)
    but above poster is correct the RPMs will vary depending on SOC ...below 55% rpms will be 500 rpms higher on average to compensate to charge the battery, once above 58% rpms will reduce to save gas. 60% is the sweet spot for normal operation
