CVT fuild change.....
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dipper, Jul 6, 2008.
  1. satwood
    satwood Member
    107
    16
    Webster, MA, New England, USA
    2014 Prius v wagon
    Wal-Mart. I drop off oil and ATF fluid there all the time. They take it.
  2. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I'm also pretty sure that you can dump ATF at the collection bin at both Autozone and Advance Auto Parts.
  3. Paul R. Haller
    285
    43
    Walnut Creek
    I did the CVT oil change Sunday and with tax the fluid was 34$. I took the old to Autozone although it was so black you couldn't tell it was ATF. 35,055 miles on the odo. 4 quarts was a little too much. Maybe 6 oz too much. I can't figure how this stuff is lifetime given it's color at 35,000. What about brake fluid and the long life coolant? I know on other cars I have owned we did a brake fluid change every 2 years but on a Prius it's not as simple. I think a scan tool is need for both the long life coolant change and brake fluid change.
    -Paul R. Haller-
  4. Patrick Wong
    18,210
    6,517
    Hi Paul,
    I agree with your observations regarding the ATF, so I change that at 30K mile intervals. Further, my used fluid testing showed that the viscosity had declined almost 15% after that amount of usage.
    Regarding the coolant change, that is a DIY project but it is not easy to get all of the air out of the engine coolant loop if you drain the coolant heat recovery canister. So plan to spend lots of time on that if/when you decide to tackle that job.
  5. tochatihu
    tochatihu Senior Member
    9,911
    3,837
    Kunming Yunnan China
    2001 Prius
    Hydraulic brake fluid life is controversial in some circles. In Prius this fluid is not worked so hard as in other vehicles, so a small amount o fwater might not lead to heating, boiling and brake fade. However, in any vehicle, water absorption will eventually corrode system components. Thus both water and %copper increase over time.
    Most brake shops have test strips that measure one or the other of those. If your fluid tests high, it's time for a fluid change. With NHW11 Prius it's (apparently) DIY, but with newer versions one has to command valves to open and close via the DLC. Still could be DIY if you have the equired equipment.
  6. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Pat,
    I just had both coolant loops done at the dealer at 150,000 miles in my 2004 Prius (along with new water pumps(2), serpentine belt and thermostat as preventative maintenance ~$1000). The dealer failed to get all the air out in the engine coolant loop causing a P1121 code (check engine light, over temp warning with "!"). After a tow back to the dealer, he corrected the problem on the second try (I passed on him replacing the "Coolant Flow Valve" per TSB EG001-08 which replaces TSB EG024-05 for $300). As you said, getting the air out can be tricky.
    JeffD
  7. Patrick Wong
    18,210
    6,517
    Hi Jeff,
    Thanks for relating your experience. Its interesting to hear that even the dealer techs with access to the correct diagnostic laptop are not achieving perfect outcomes on this procedure.
    For DIYers who are not confident they can successfully refill the CHRS canister (or don't like my approach of repeatedly shorting the CHRS relay terminal contacts for brief periods to force the CHRS pump to run when the car is IG-OFF), an alternative would be to just open the engine block and radiator drains and leave the CHRS canister drain closed. Then only the radiator and engine will need to be refilled.
    This alternative is not a great one because even with all three drains open, only around 2/3 of the old coolant will be drained (as some coolant in the cabin heater core loop remains.) Therefore, if a DIYer is going to follow this simpler procedure, I'd suggest doing the first engine coolant change sooner than 100K miles, maybe at 60K or 70K (as even more old fluid will be left in the system); and the subsequent change should definitely be no later than 50K miles after the first change.
    Also, DIYers should not forget to squeeze the radiator hoses and open the vent on top of the radiator while working to purge air out of the system. You'll need a small hex key wrench to open that valve.
  8. Don Rossetti
    Don Rossetti Junior Member
    Hello from sunny, nutty Tucson,AZ: Greatly appreciate your posts. I've done the oil changes on my Gen II 2005 pkg 5 about every 3000 to 3500 miles since it was new and have followed the discussion on the transaxle fluid with great interest. I'm one who believes that frequent changing of an auto's fluids is generally good policy. There are two dealers here, both of which originally recommended changing this fluid at 90K to 100K. Later they changed it to 60K. As a person with some leftover mechanical ability from the hot rod days of old, I'd be happy to do it myself every 30K but wonder exactly where the two drain plugs are. So could you possibly describe their location in relation to, say, the engine oil pan or filter. I've not looked for them yet, but it sounds like it is possible for a rookie to mistake them for something else. Also am wondering about the need to change the serpentine belt and the PCV valve. I bought a PCV the other day thinking I could do it myself, but one guy on here says it takes two hours. Wonder just where they put the damned thing and what it takes to get to it. This car has 63,500 absolutely trouble-free miles and anything I can do to reward it with TLC I will happily do. TIA.
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Forum member Hobbit took this photo, I added the arrows to illustrate the location of the drain and fill plugs
    You will need a hex socket on the drain plug. Don't touch the regular looking drain plug near it, that's the inverter coolant drain
    You live in a hot climate that rarely has cold temps. I don't think I would worry too much about the PCV valve. Living in a climate like mine, with -40 winter temps, there is a lot of moisture and vapor in the engine, and the PCV valve will gum up sooner
    Rather than replace the PCV valve, in other vehicles I've just taken them off every Spring, given a blast of carb cleaner, and they're good as new again
    4 people like this.
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    Flushing out the brake fluid on a Prius is absolutely NOT a DIY procedure. I've posted the relavent shop manual section on this, you absolutely need the dealership scan tool to command solenoids and pumps.
    http://priuschat.com/forums/gen-ii-...em-rear-brakes-no-pressure-when-bleeding.html
    When I had my Prius, every 2 years I had the dealership flush out the brakes. They charged me $80 to do the work, and thought it was a good idea. I'm a bit anal about how I look after my vehicles
    With my FJ, unless the master cylinder runs dry, I can bleed the brakes as DIY. However, it's still a different procedure compared to older vehicles
    As the FJ also has electric assist brakes, during bleeding the key must be on. The rear brakes, the helper has reported that when I open the bleeder, the brake pedal doesn't move, but the pump keeps pumping brake fluid. Actually makes bleeding a lot easier
  11. Patrick Wong
    18,210
    6,517
    Re: CVT fluid change.....
    Hi Don,
    Jay answered your question about the transaxle drain/fill plug locations so I'll address the rest. The PCV valve is hiding below the engine wire harness that runs along the valve cover. That job could take two hours the first time you do this because you have to remove the cowl assembly that runs below the windshield first. Then you can unbolt the wire harness from the valve cover and the PCV valve will be exposed. See galaxee's post here:
    http://priuschat.com/forums/knowledge-base-articles-discussion/56852-pcv-replacement-how-photos.html
    Regarding the serpentine belt, please see my post #18 in this string:
    http://priuschat.com/forums/gen-ii-...45143-service-schedule-serpentine-belt-2.html
    BTW, I've just purchased a home in Green Valley (Robson Quail Creek) and will be moving there in a couple of weeks. ;)
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    I actually beat you on a post. You must be feeling under the weather. Or, are very busy with the move
  13. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    Hello all:
    Regarding the CVT fluid refill: some have said that they can't get the full 4 quarts in. Has anyone tried measuring the amount that they removed, and then put that same exact amount of new fluid back in?
    Just a thought.
  14. yardman 49
    606
    77
    Northern Kentucky
    Hello all:
    Regarding the CVT fluid refill: some have said that they can't get the full 4 quarts in. Has anyone tried measuring the amount that they removed, and then putting that same exact amount of new fluid back in?
    Just a thought.
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    I tried that once. Got out 3.92 litres, put in 3.89 litres. I didn't account for residue in the drain pan or residue left in the pump
  16. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    How did you measure the volume with such high precision? :confused:
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    I had a contract at a small chemical plant around 11 years ago. It was being dismantled and we were sent in to pick over the carcass, find valuable parts of the control system, etc.
    So I .... um ... "liberated" some very nice instruments from the QC lab
  18. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    Just for information. In Toyota Europe's service manual for Prius (NHW20), transmission fluid change is recommended every 90000 km (approx 60000 miles) or every 6 years (72 months) for cars under severe driving conditions and no change is needed for cars under normal driving conditions.
    So probably changing it at least for the first time after approximately 60000 miles, is not at all bad decission. Afterwards it probably does not make as much sense unless you are driving under "severe" conditions.
  19. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,804
    1,170
    Auburdale FL
    Nice job! Anyone do the same for the crankcase?
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    Based on the reports here, and my personal experience with my '04 Prius, an early initial change at around 10,000-16,000 km is most benificial.
    Subsequent fluid changes, the fluid remained very clean and held up well
