1. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    Did you ask them what they would do during a CVT rebuild? I would check that with them just to be sure they know what they are talking about. As soon as they start about belts and pulleys walk away.
  2. CuriousXM
    CuriousXM New Member
    I had the same issue 2004 GenII, 315000 km. Maybe worse (more of a rumbling). Problem started at 30 km/h and was unbearable above 100 km/h, went away when turning to the right. Replaced many items (tires, bearings all around, axle driver's side, cvt fluid) before noticing excess play of passenger side axle at the cvt. Once this was replaced the problem disappeared. Such a relief. Good luck!
    I realize this is late, but hopefully it helps someone.
    #42 CuriousXM, Jan 17, 2024
