CVT vs ATF
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mazen, Jul 6, 2016.
Tags:
  1. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Toyota CVT Fluid FE exists here, as well - it's for things like the Corolla and Scion iM with a pushbelt CVT, here.
    I could see the confusion, because people refer to the Prius gearbox as a CVT, and it behaves like a CVT... but it really isn't one, and the lubrication requirements are much more similar to those of a conventional automatic transmission (hence the Prius gearboxes using the same lubricants as Toyota's conventional automatics).
  2. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    Just go back and show them the user manual, demand a free change with the specified fluid.
    I find some of the above strange, do you really believe the fluid itself has to withstand 600 V DC? I really doubt it.
  3. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Hmmm. I suggest you refer to your owner's manual. US manuals plainly show WS as well as the Canadian manuals.
    If you don't have a manual, you can download one from Toyota's website.
    Toyota Online Owners Manuals and Warranty
    http://www.toyota.com/t3Portal/document/om-s/OM47668U/pdf/OM47668U.pdf
    2010 Prius Owner's Manual ^ ^ ^ Refer to Page # 563 in the manual. Plainly shows Toyota Genuine ATF WS Fluid.
    #23 dorunron, Jul 16, 2016
  4. Mendel Leisk
    42,376
    If it's resolved that it is indeed the wrong fluid, I would ask for a triple change, with a day or two driving in between each change, to better flush the old fluid out. Perhaps contact corporate Toyota if they balk.
    Prieth and dorunron like this.
  5. bhtooefr
    1,396
    1,489
    Newark, OH, USA
  6. Patrick Wong
    18,214
    6,530
    1. The stator windings must carry up to 500VAC, three-phase.
    2. 500VAC RMS for a sine wave translates to 1.400 volts peak to peak.
    3. The stator windings use insulated wire and the windings themselves are wrapped.
    4. However, the insulation may break down over time due to exposure of the windings to heat, the ATF, etc.
    5. Hence, the ATF may be exposed to electrical current, and to the extent that it conducts electricity, that will cause further breakdown of the winding insulation and eventually cause a ground fault which will be logged by the power management control ECU, thus preventing further vehicle operation.
    Merkey likes this.
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  8. GasperG
    1,169
    601
    Slovenia
    2018 Prius
    Why do I have a feeling if this happens you are in deep sh*** with any fluid.
    m.wynn likes this.
  9. Nashwan
    Nashwan New Member
    Sweden
    Business Edition
    hello pls i have prius 2010 how much litter tacke Prius gearbox as a CVT? and my car 100 000 km i must change it thanks
  10. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
  11. Threej
    Threej Member
    99
    99
    Portland, OR
    Haha, I'm glad you understood the question.
    PriusGuy32, Nashwan and Mendel Leisk like this.
  12. Mendel Leisk
    42,376
    Prieth, m.wynn, Nashwan and 2 others like this.
  13. Patrick Wong
    18,214
    6,530
    3.4 liters or 3.6 US quarts.
    Nashwan likes this.
  14. Nashwan
    Nashwan New Member
    Sweden
    Business Edition
    thanks
