Cylinder 1 and 3 Misfire Troubleshooting for a new owner
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tolan, Feb 6, 2017.
  1. Tolan
    Tolan New Member
    Missouri
    I
    So I just bought a 2010 Prius with almost 200k miles on it. Like, I don't even have plates on it yet (had about 2 weeks now). My mechanic did a pre-sale inspection and said it looked more or less fine, especially considering the miles.
    A couple days ago the check engine light turned on. I finally got around to checking it, and it's saying misfire in 1 and 3. As an insult to injury, my wife's car refused to start today (Likely a starter issue), so this is now our only wheels.
    We were having a bit of a cold wave when the light turned on, and I haven't notice anything obviously wrong, but my experience is so brief I don't know if I can trust myself to have a good baseline. I can here a faint dakadakadaka (I do not know if that's a rattle or a knock) if I leave the radio off while the engine is running, and the only time the engine significantly shakes the car is the first time the gas engine kicks in (Usually about 30 seconds after powering on) after having been parked for a material length of time.
    Can anyone give me some guidance on what the likely issue is, what I'm looking at to resolve it, and how urgently it needs to be done? I skimmed the stickied manifold thread, and that seems like it might fit? But it's been warming recently, and there were many reporting that issue resolving itself when weather warmed back up, so... I do not know if that's worth pursuing in that case.
    Also, as a final note, I'm not super fluent in car jargon, let alone Prius jargon, so if you could make an effort to explain more complicated technical terms you use, I'd appreciate it.
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    If you have to add coolant than you have a blown headgasket.
  3. NavyLCDR
    NavyLCDR Active Member
    188
    121
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    If it's original spark plugs you can try replacing them. Over 200K on plugs is pretty high. There is quite a bit of "stuff" you have to remove to get to them, but it is a medium-level experience at home job to do.
  4. mattdhurley12
    mattdhurley12 New Member
    29
    El Dorado Hills CA
    I was having same issues with cylinder 1, diagnosis was blown head gasket.
    iPhone ?
  5. Mark Forhan
    Mark Forhan New Member
    Waterloo, Ontario, CANADA
    Tankyuong - you've got it right! That was my issue with 2010 Prius - unfortunately found out too late - end up with warped engine block.
