Cylinder misfire. Help!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Aaron Vitolins, Mar 5, 2017.
  1. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Take your time laying out the nuts and bolts as you remove each one. It helps to have a large table or clear space where you can lay them with their associated parts, or write down where they came from. With that engine cowling, it can take up a LOT of room, but this will save you a lot of frustration when you reassemble. If you have a helper, this is something for them to do while you’re tearing out parts.
    Using a power tool to remove bolts is great, but always always hand thread them back on, and then you can use the power tool. Otherwise, you’re guaranteed to strip a thread sooner or later.
    Good luck, have fun, play rock and roll as you work.
    Raytheeagle likes this.
  2. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    This will be the 2nd time for the egr system for me. And 3rd time removing the wipers.
    The wipers assembly is a 5 minute job. Actually, 4th time. Had to remove it for the new windshield.
    I just lay the nuts and bolts aside, they only go one way. Like I said. VERY easy!
    Everyone seems to want to make a big deal of it, but it really isn't.
    Toyota will have the last 3 gaskets I need for the egr system tomorrow.
    I have everything else already.
    I don't need any power tools for this. I never overtighten nuts or bolts. Since I'm the one who
    removes them the next time, I want to make sure it will be easy! :)
    I can't remember which decade it was I last stripped a bolt. I've had to fight with the last person
    who did and I was the lucky one to work on it next though......
    I don't have a compressor so I can't use my air tools anyway.
    If I had more time next week, I'd replace the valve guide seals. But it's in the near future!
    This truly is a one man job. The hardest part for me is leaning over the fender so much.
    Kills my antique back! And I use my van to store the parts.
    But thanks for the help and info! It will also be good for someone doing it the first time. (y);)
    Robert Holt likes this.
  3. NorCal PiP
    NorCal PiP Junior Member
    San Carlos
    2013 Prius Plug-in
    2013 Plug-in 156,000 on motor. Paid 6700 in February. No oil consumption. Out of no where p0131 cel, misfire. Drinking coolant. Second owner. Good maintenance records. This is a piece of shit motor. Very disillusioned with the Prius reliability. This thread tells me that Get 3 blown head gasket is a known flaw. Should have stuck to Mazda 3 and my Civics that have both surpassed 230,000 miles.
  4. Mendel Leisk
    42,345
    Too bad. P0301?
  5. evilchargerfan
    evilchargerfan Junior Member
    24
    42
    San Diego
    going from a ct200h (3rd gen prius motor) to a 2015 honda fit, was a decision I dont regret.
    similar mpg, much easier maintenance, lower ownership cost.
    I for one dont miss driving a hybrid.
    (fun fact, just sold my 2000 honda insight a week ago, I do genuinely miss that little thing. 60+ mpg was so darn sweet)
  6. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    Definitely the turd gen!
    I think the 4th gen will be a much more reliable long term vehicle like the old Gen 2 Prius.
    my sister Prius is on it’s second engine in her 2010. The second engine was from a 2013 plug-in, now it’s blown too with only about 145k. It’s got 277k in the hybrid battery with no issues.
    I already know of someone with over 300k on his 2016. No oil consumption, or any issues at all. I think he did have a wheel bearing or two. He gets over 50 mpg driving over 80 MPH all day long. Amazing
    tankyuong and mjoo like this.
