Cylinder misfire. Help!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Aaron Vitolins, Mar 5, 2017.
  1. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    Here is a picture of my sister and her car!
    Mendel Leisk and m.wynn like this.
  2. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Here my car and I. Let's make this all about me! Haha sorry off top guys.. but hey! We all like Prii here
    Tracksyde and m.wynn like this.
  3. Manjot Sandhu
    Manjot Sandhu Junior Member
    17
    Seattle, WA
    Main Head gas kit
  4. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    No it's shot. It eats oil like crazy too. Btw it isn't mixing fluids at this time
  5. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Just a piece of crap :)
  6. Manjot Sandhu
    17
    Seattle, WA
  7. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Not that you can see from the drivers seat
  8. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Aaron, how did you guys prove it was the head gasket leaking vs. the egr cooler itself leaking into the engine? I would think that either would produce the same symptom.
    I'm just curious since I haven't worked with this problem before.
    m.wynn likes this.
  9. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Rapid coolant loss. I bet the EGR system is all full of carbon build up for sure, it's drinking fluids like crazy. A clogged EGR system just makes it run like shit.
  10. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    Aaron,
    I think what @mjoo is getting at is that the EGR cooler (remember, the engine coolant loop runs through it to create this "cooled EGR") could actually be "blown" and leaking coolant from it's internal circuit, back into the exhaust manifold. From here it could be getting into the combustion chamber via open exhaust valves when the engine is off. Then when the engine fires, it's going to burn coolant and misfire. Any coolant remaining in the exhaust manifold will be smoking/steaming out the exhaust, too. All of this combined with obvious coolant loss from the reservoir might impersonate a blown head gasket quite effectively. This is an excellent theory, IMO. The EGR circuit could be behind much more trouble than simply the "missing under light throttle" nuisance we've thought it to be.
    #90 m.wynn, Mar 24, 2017
    Mendel Leisk and Aaron Vitolins like this.
  11. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Thank you for explaining that to me. This wouldn't have anything to do with rapid oil loss would it? One of the main reason I'm much more inclined to call it a head gasket leak is all the other members that have had the same symptoms, and have gone to the dealership and in fact it was the head gasket. Apparently pretty common :(
  12. m.wynn
    684
    1,230
    Queensbury, NY
    I should clarify that I'm not saying these blown head gaskets aren't indeed blown head gaskets. I'm just saying that of all the reports we've had here, I don't believe we've had a single instance of verification of cause. What if an entirely different system failure is throwing up apparent HG failure symptoms?... And one that's easily fixable for a few hundred bucks... I think you and your dad could be the ones to tell PriusChat what's up with the "coolant usage" issue these engines are having!:D(y)
    The oil burning in these engines is a piston, oil control ring issue and unrelated, IMO. It's been long documented even since the 90's with Corolla owners. The control rings stick tightly with carbon coking and the piston oil return holes clog completely. Lets the oil blow right by and into the fire. This is why good quality full-synthetic is a must and 5k miles OCI good insurance against the problem developing. Toyota was late to the 10k mile OCI recommendation party and I bet they never would have shown up if not for CAFE pressure. I'm flame suit on here, but whatev.
    Aaron Vitolins and Raytheeagle like this.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    To expound on @m.wynn 's point, you and your father will have a great opportunity to help the community out;).
    Would you be able to do the following after the "new" engine is in the car and operational:
    1. Save the old engine
    2. Harvest the egr cooler and save it and the valve for pressure or water testing
    3. Harvest the water pump
    Set these aside for testing later.
    Curious if 12v load is applied to the water pump what happens and if the impeller is spinning or not.
    Water test the egr cooler by hooking up hoses to the water side (depending on overall cooler cleanliness on the exhaust side) and see if you get water out of the exhaust gas side. You'll need a couple of hoses, easily obtainable.
    Keep us posted(y).
    Aaron Vitolins and m.wynn like this.
  14. Manjot Sandhu
    17
    Seattle, WA
    Let me tell you the solution if you have engine check light on with code p0301,2,3,4 means one of the cylinders misfires get the tune up done also clean up the intake manifold,EGR pipe and pcv valve. If all of this doesn't make it go away then could be your fuel injectors. Coolant loss could the water pump or maybe leaks check for that as well check for any leaks. Two symptoms if your head gas kit is out is mix of coolant in oil plus white smoke and engine check light with misfire engine
    Aaron Vitolins likes this.
  15. m.wynn
    684
    1,230
    Queensbury, NY
    No peer pressure, of course...:whistle:
    Raytheeagle and Aaron Vitolins like this.
  16. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Ohhhhh the pressure is on! *bites nails rapidly*
    m.wynn and Raytheeagle like this.
  17. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    If I were closer, I'd offer to help(y). It's always good to test and get data:).
  18. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Thanks man! Boy, I really wish you were. I feel that we could really carry on a good conversation about Prii and hybrids. Nobody in my life knows much about them, but I tell them and try to have good conversation about it anyway! Lol
    Raytheeagle likes this.
  19. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    If you were out here tomorrow, we're having a meetup. There will be at least 4 of us: 1 Gen2, my liftback and 2 PIPs.
    Where I work there are a lot of Jeeps and urban assault vehicles. When I told them I was racing around Sonoma for the Prius Challenge they asked in what. I told them in a Prius and got this response::rolleyes:o_O:sick:
    But out here I am in good company;).
    m.wynn likes this.
  20. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Hopefully I'll take my v to California one day (before the head gasket blows of course ;) ) and make it to a Prius meet up!
