Cylinder misfire. Help!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Aaron Vitolins, Mar 5, 2017.
  1. Manjot Sandhu
    Manjot Sandhu Junior Member
    17
    Seattle, WA
    Nice how many miles on engine?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Local or online?
  3. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    44 thousand miles. We bought it at a local yard. They know us there! We've bought a lot of stuff from them
    Raytheeagle likes this.
  4. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Yes I think preventative maintenance is key. I just cleaned the EGR pipe in my V and the "new" engine
  5. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    This is from my v with 106k
  6. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Pics tell a story.
    Looks like a cleanse is in order.
  7. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Cleaned it all up! Starts up smoother than it has in a long time!
  8. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Good to hear(y).
    Soon you'll be doing the intake manifold and egr valve and cooler:)!
    Aaron Vitolins likes this.
  9. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    True!
  10. Mendel Leisk
    42,360
    To remove the intake manifold you need to remove the throttle body. Just wondering: when removing throttle body is it mandatory to disconnect coolant lines? Or can you just leave them connected and pull the throttle body off and out of the way enough? Also, how necessary is it to replace gaskets?
  11. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    I disconnected the coolant lines as part of the egr cooler removal. Since the coolant was out, it made sense to do it then and easier to root around the engine bay;).
    If you pool services together , you can get more done, but requires a larger time commitment.
    If you were going to do the throttle body outside of a coolant drain, hose clamps and corks should be employed to avoid coolant all over the engine bay. You could also slide it out of the way, but may prove too difficult to remove the intake manifold and put it back in.
    But if someone wants to try it, that feedback could help(y).
  12. Currahee
    Currahee Member
    103
    34
    CT
    Here's a video of someone doing the intake manifold cleaning:
    Aaron Vitolins and Mendel Leisk like this.
  13. Mendel Leisk
    42,360
    Thanks for that. It looks like no coolant hoses disconnected: they unbolt the throttle body and just move it off to the side.
  14. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Starting the removal process tonight!
  15. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Wide view :)
  16. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Excellent :)!
    That looks like a nice garage too;)!
    Keep the updates and pics coming(y)!
  17. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Thank you, Ray! Dad enjoyed the comment about the garage :)
    We will keep everyone updated!
  18. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Best tool ever! Thanks Diesel tech Ron. R.I.P :(
    danlatu and Raytheeagle like this.
  19. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    @Raytheeagle, do you think we should make a better video of the combination EGR remove/oil catch can install/intake manifold clean when we attack my car next month?
    Aaron Vitolins and Raytheeagle like this.
  20. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Sounds like a plan ;).
    No @NutzAboutBolts available, so I'll bring my video camera and we'll see how it goes!
    Hopefully you are photogenic (y).
