Cylinder misfire solved
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by milkman44, Jan 6, 2018.
  1. douglasjre
    douglasjre Senior Member
    2,227
    743
    Null, NL
    I was wrong again. It still has startup knock. Teh radiator cap was bad so after changing it the system comes up to pressure and now it knocks again. It also uses antifreeze and there is no bubbles or oil in the antifreeze. Could it be leaking around the air flow sensor/throttle plate? If it were leaking at the head wouldn't there be dirt/residue or oil or air bubbles in the antifreeze?
  2. Mendel Leisk
    42,119
    One thing to keep in mind, if you're using the spec'd Toyota coolant: it comes pre-mixed, 50/50 in the States, so once you start putting significant amounts of water in the system, to get back to 50/50 mix you would need to drain and refill several times I think, to flush the excess water.
    There is no radiator cap.
  3. douglasjre
    2,227
    743
    Null, NL
    What shall we call the
    What shall we call the pressure cap on the circulation tank?
    On point: Where might coolant be going that is not head gasket related and yet getting consumed? Throttle body? Do these leak?
  4. Mendel Leisk
    42,119
    Reservoir Tank Cap?
    Tande and Raytheeagle like this.
  5. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Boy, talk about thread hijack! ;)
  6. Tcortez
    Tcortez Junior Member
    25
    42
    Lancaster
    Did he ever find the problem , I’m experiencing the same problems. Please post feedback.
  7. Tcortez
    25
    42
    Lancaster
    [​IMG]I found my issue , I bought a cheap iPhone boroscope and found cylinder #2 has coolant in it. I guess I have a blown head gasket, the car has 220,000 miles , I went to Autozone and bought some K seal, , I’ve been losing a little bit of coolant every night. I hope the k seal helps my car out.
  8. Mendel Leisk
    42,119
    I wouldn't use that stuff, clogs up the entire coolant circuit, including cabin heater core?
    milkman44 likes this.
  9. milkman44
    milkman44 Active Member
    591
    386
    Ky
    The only way I'd use that stuff is to limp it straight to a lot to trade it in.
    douglasjre and amos like this.
  10. Mendel Leisk
    42,119
    Why I always buy new.
    Raytheeagle likes this.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    I will be tomorrow:).
    Why take chances;).
    Prime for a Blue Magnetism upgrade(y).
    The Critic, amos and FnRedPrius like this.
  12. Mendel Leisk
    42,119
    You've been sitting on that eh. (y)
    Ah too bad, you'll be losing interest in EGR cleanse now...
    RMB and Raytheeagle like this.
  13. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Meh, we’ll still have meet ups out here;).
    I have @Pedal Logic ’s on the docket for next Friday :).
    But I guess it’ll be in a different vehicle than when the appointment was made(y).
    The Critic and Mendel Leisk like this.
