Cylinder Misfires
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Justin Henderson, Jul 12, 2023.
  1. Justin Henderson
    Justin Henderson Junior Member
    Salt Lake City
    2014 Prius v wagon
    SOS!
    2 Days ago my 2014 prius V threw a cylinder 2 misfire error code and was very rough on starting. I was due to change the plugs, so I went ahead and did so. While changing them, I also swapped the cylinder 2 coil with the cylinder 3 coil to see if the error would follow the swap. I reset the code. Today it was a rough start again and now the error code is reading a cylinder 2 and 4 misfire. Should I just change all the coils? What would my next step be?
    stv likes this.
  2. Brian1954
    Brian1954 Senior Member
    2,686
    1,073
    South Central PA, USA
    How many miles on the car?
    It could be a bad head gasket. It is very common for this engine if it is over 140k miles.
    Check the level of the engine coolant.
    When the head gasket goes bad, engine coolant will seep into cylinder 1 or 2 and cause misfires, especially during cold start-up. The engine coolant level in the plastic tank will go down very slowly at first.
    Tim Jones likes this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,108
    6,969
    Texas Hill Country
    A severe metal to metal sound at startup that goes away for the rest of the day and sometimes days or weeks is early hg fail. A replacement hg may work but often fails again. A rebuilt engine is the best bet.
    At this stage a high quality dual camera borescope used with coolant pressure can be diagnostic under experienced eyes. Steam cleaned piston compared to others and sometimes a coolant seep can be seen.
    Or you can throw a thousand or two into plugs, coils, egrs and feel good for a few weeks. You will get suggestions how to throw away dollars.
  4. Mendel Leisk
    42,347
    Dibs on 150K.
  5. Justin Henderson
    Salt Lake City
    2014 Prius v wagon
    138000 miles. No severe metal on metal sound. Just shudders when motor starts from cold. Then runs ok.
    stv and Mendel Leisk like this.
  6. rjparker
    11,108
    6,969
    Texas Hill Country
    Practically nothing but a hg. Shutter then run ok.
  7. Brian1954
    2,686
    1,073
    Sound like the early stages of a failing head gasket.
    Did you check the engine coolant level?
  8. Mendel Leisk
    42,347
    Time for boroscope inspection of cylinders (with cooling system pressurized) and/or leak-down test.
    EGR system and intake manifold EGR passages never cleaned?
  9. Stephen Herman
    Stephen Herman Junior Member
    17
    North Carolina
    Same thing happened to me (cylinders misfires) Replaced head gasket. Strange thing about this car doesn't use a drop of oil. Never has 3 months owned it. Guess cylinders must still be in great shape with around 250k miles. Read on this board from Mr. Leisk and others that prius prone to clogging up exhaust manifold affecting couple cylinders. Told to clean it out every 60 k miles by mechanic for 200 dollars. Save another head gasket replacement.
    #9 Stephen Herman, Jul 12, 2023
  10. Justin Henderson
    Salt Lake City
    2014 Prius v wagon
    Ive had the car since 100K and I haven't had them cleaned. I wasn't aware it was required. Good to know going forward.
  11. Mendel Leisk
    42,347
    100k’s about the latest you want to delay that. Sooner is better. There’s a correlation between clogged EGR and blown head gasket.
    orenji likes this.
  12. Justin Henderson
    Salt Lake City
    2014 Prius v wagon
    Thanks for the help. Taking it to the dealership in the next day or so. Unfortunately, where we live, nobody works on hybrids.
  13. Justin Henderson
    Salt Lake City
    2014 Prius v wagon
    So here's an update..
    I found a mechanic in my town who said they could take a look at the car. Explained to them that I had swapped the plugs and switched coils 2 and 3.
    I got it back today. They said that they couldn't recreate the misfire. They did do a block test which they said it failed (though not immediately). They then said that because it failed the block test, it is not likely an injector, etc.. They said it's likely a head gasket or EGR which they don't do and they are punting me to the dealership. I've driven it a little bit here and there today, and it is running perfectly and has no error codes.
    Do you think I should just still take it to the dealership to have them evaluate the EGR and HG?
  14. Mendel Leisk
    42,347
    Block test tests for carbon monoxide in coolant, which is not what typically happens, at least not first. The tests I mentioned in post 8 are more conclusive. In particular the boroscope inspection, which should be be with coolant system pressurized, looking for coolant leaks into cylinder.
    Having dealerships diagnose and deal with clogged EGR can be very expensive and fruitless; they will only replace parts, won’t “stoop” to cleaning, and the parts (EGR cooler/valve/pipe and intake manifold) are about a grand USD, and then there’s the labour. If there’s anyway to DIY I’d go that route.
  15. Leadfoot J. McCoalroller
    8,289
    7,802
    Pennsylvania
    2018 Prius c
    Keep looking for an independent mechanic. Dealerships are a very expensive choice for old cars.
    Head gaskets are head gaskets. The methods to diagnose and replace them are ridiculously similar whether it's a 1972 Dodge or a 2014 Prius.
    The EGR cleaning is a weirder situation. There are no official stats, Toyota has never acknowledged a problem nor made a recommendation either way.
    Montgomery and Air_Boss like this.
  16. Justin Henderson
    Salt Lake City
    2014 Prius v wagon
    My fear is that it's alittle too in depth for my non mechanical brain. Changing the spark plugs is the most I've pulled apart an engine before. Other than that, I've only been doing oil changes etc..
    I am very hesitant to take it to the dealership for the reasons you mentioned. But I live in North Idaho (nearly Canada) where nearly everybody drives trucks. I've called all the mechanics in town, none work on hybrids except for the one I took it to but he said that what seems to be going on is beyond his scope.
    How involved of a process is it to clean out the EGR?
  17. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    Justin, due to your location, take a look at the links on Mendel's thread. Then from there, you will also find videos on how to do the complete job. I agree with everyone, regarding going to a dealer. Unfortunately, the dealer is only going to do what is necessary to stop the current problem and not fix it so it will run another 100k miles. There has to be someone in your area who is familiar with doing a head gasket job on an engine. And while they are doing the hard part, you could be cleaning the other parts that are clogged.
    Where you are right now is going to take time to save money or spend a heck of a lot of money to try and save time. Choice is yours. Wish you the best!
  18. Leadfoot J. McCoalroller
    8,289
    7,802
    Pennsylvania
    2018 Prius c
    It's pretty advanced for a newbie, and won't actually fix the current problem.
    It might prevent it from happening again, but somebody's still going to have to deal with the head gasket.
    John March and Mendel Leisk like this.
  19. rjparker
    11,108
    6,969
    Texas Hill Country
    When the dealer tells you it's $3500-$4000 for a head gasket (or much more for a rebuilt engine) turn around and leave. You can have a complete rebuilt engine shipped in from Southern California installed for that money. Almost any conventional mechanic can change the engine with a quality rebuild engine. You get a remanufactured head, new pistons and rings and a complete new seal set, including of course the head gasket. EGR cooler and intake must be cleaned. I usually recommend people replace the plastic intake which is hard to decarbonize and there are revised versions now.
  20. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    I had a similar situation. Had the rough idle engine sputtering at startup. it happened .3 times. On the 3rd time, the check engine light came on.
    took it to the dealership and read the dreaded code P0302, Cylinder 2 misfire.
    Checked the coolant level and oil level.
    All fluid levels are at normal levels.
    Now this was my problem. I had to drive the car back from Arizona to California. I’ve done this trip many times and this was the first time I ever had this problem.
    Since the engine light was solid and it was not blinking, the service advisor and I decided to reset the code and turn the engine light off. He said to monitor it and if it comes back on, then we can read the code again and then really get into the diagnostics.
    for good measure, I added the Toyota OEM fuel injector cleaner and then filled up the tank for the drive home. I’m taking a big risk considering it could be the start of a head gasket failure. If it’s something to do with the coil packs, spark plugs, fuel injectors and/ or EGR then I guess that would be better than a head gasket problem.
    I was ready for the worst case scenario, driving through the Arizona dessert at 112 degrees.
    Drive the car for hundreds of miles and was planning to drop the car off at HybridPit in Orange County.
    when we got to our halfway point in Fontana, Ca., we filled up at our favorite Costco Gas station. My car was was running like a champ, no engine lights so far.
    at this point, I was confident to drive it all the way home. I cancelled my rental car reservations and went the rest of the 340 miles into Northern Cali.
    made it back at 10:45 pm and the car was amazing! No engine lights and the car drove like nothing ever happened. All fluid levels are good and engine temp were all within operating range. Have 2 Scangauges monitoring the temps.
    i know there’s a problem but until the light comes back on, hard to say what needs to be repaired.
    here’s a picture of the Toyota oem fuel injector cleaner that I added before my trip back to Cali.
    Been driving the car around town. All good.
    If it wasn’t for the 3 rough idles at startup and the engine light coming on, you would never know anything was wrong with the car.
    Driving the car back 700 miles from Arizona to California without any problems, makes me hopeful that my car problems is not as serious as initially thought. Or maybe not. Only time will tell and whenever the engine light comes back on.
