d#mn aluminum hood!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mgb4tim, Oct 30, 2009.
  1. hptsang
    hptsang Member
    139
    Houston, Tx
    I heard of a few friend's friend die from driving a Miata
  2. concertinajohnnyboy
    104
    Minneapolis
    I'm happy that it is aluminum. Thank you Toyota.
  3. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    MGBs are like Corvairs, only their owners can seriously enjoy them. As we approach 2010, I can't believe people are still hanging onto their old 1950s car given they are not safe or fast. I guess it's cool if you are into that kind of stuff.
    I have driven them, my Prius can lap faster than a regular V6 MGB at the track (which I did do). If you like those cars, that's fine. Let's not go so far as to say how great they are...
  4. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    Lord only know how hard you'd criticize my TR7.
  5. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    Living where salt is used on the roads in the winter, I'm grateful for the aluminum hood and of course the weight reduction is nice. I have received two paint dings on it that are only a quarter of an inch apart. No dent in the metal and I don't know when it occurred as I was never startled by the loud sound of a rock hitting the hood. It could have been intentional (vandalism) but I don't think it was.
  6. iota
    iota New Member
    Columbus, OH
  7. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
  8. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    :rofl::rofl::rofl::rofl:
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Do Prius in the U.K. have an aluminum hood, or do they come with an aluminium bonnet?
    Tom
  10. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    Hello,
    If you would like to make a carbon fiber hood for the 2nd gen Prius I would be willing to allow you to mock it up using mine (since we live in the same state). I also believe my shop foreman toyotechwv would be interested as well.
    Take care,
    Josh
  11. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    They'd have an aluminIum or alloy bonnet. No hood, since it's hoods are generally for dropheads. :D
  12. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    Josh - I'm in Fairmont, about 3.5 hours away. I'd need your hood for a few days to make the mold. The gel coat and fiberglass are so thick, that I like to let them stay on the part a couple days before I pull them from the plug.
    Were the 2nd gen Prius hoods steel or aluminum? I don't think there'd be much of a weight savings over aluminum, but it wouldn't dent so easily, and would look cool.
  13. josh2008
    365
    144
    Princeton, WV
    Sounds good, we can work something out. The 2nd gen also has the aluminum hood. Any estimate on price for you to make a carbon fiber hood? Also, would this destroy my factory hood? No big deal if it would, I'm interested in the look of the carbon fiber hood on the Prius.
  14. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    If I prep the hood properly, like any of my mold, it won't damage the hood. I scrub it, affix a flange around the perimeter, apply a few coats of mold release wax, fill any paint chips with clay, spray a few coats of a water-soluble mold release, spray a couple coats of tooling gel coat, the lay up a layer of veil, a couple layers of chopped strand mat, then a couple layers of non-woven biaxial cloth, then another layer or 2 of chopped strand - then let it set a few days.
    Then, I pull the mold, clean up the plug, and start polishing the mold surface - much like wet sanding and polishing paint.
    I do it all over again for the hood frame underneath.
    As for cost,the 60"-wide fabric is $38.50/yard. I'd use 3-4 layers. I'd bet I could use the salvage from the hood skin to lay up the frame. Probably use 2.5-3 yards
    A quart of good epoxy resin is $35. Peel-ply/breather, tape & bagging would add another $35 for both parts of the hood.
    So, materials only is about $180, probably closer to $200. I'd also need to embed steel for the hinge and latch assemblies. Then put it all together.
    Lots of labor, and would you be able to go without your hood for a week?
  15. josh2008
    365
    144
    Princeton, WV
    For that price I can't pass up the offer. Especially considering it sounds like you do very thorough work. What I'm thinking of doing is picking up a salvage hood in good condition to let you use. One question, will the carbon fiber hood have the shiny (can't think of the proper word) coat like most aftermarket carbon fiber hoods?
  16. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    The $200 is just materials. With labor and other expendables, it would be normally be closer to $450-500 - especially if you aren't in a big-big hurry. But, since you are offering the plug, I would make it really fair to you. Right now, it's my time that is at a premium, so not having your car's hood allows me a more liberal time line.
    The shiny coat is the epoxy, it's all one application. It would most likely be best wet sanded, polished, and waxed.
  17. patsparks
    10,664
    567
    Adelaide South Australia
    Bonnet, just like us colonials in Australia.
    A soft top would be a hood. The lining of the roof is a hood lining even if the car has a hard roof.
    I'm happy with my aluminium bonnet.
  18. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    A-hole much?
    Seriously...don't be a jerk.
    I don't think a lot of people would argue that a classic MG is a very cool collectible. Nobody with taste anyways.
    Anywho, the aluminum hood definitely dents easier than steel and its harder to reshape using PDR than steel...
  19. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Agreed! I had this hot girl crawling on the hood err bonnet of my Prius last weekend and it didn't even leave a mark. Well there were two rather round impressions left in the dust of the hood but whatever. :D
    *edit* to keep this clean I will have to state that I was in the car at the time!
  20. SW03ES
    2,480
    176
    Gaithersburg, MD
    That must have been terrifying! :)
