Damaged 2011 Prius - sell for parts?
Discussion in 'Gen 3 Prius Main Forum' started by chiropterist, Jan 8, 2022.
  1. chiropterist
    chiropterist Junior Member
    My 2011 Prius 2 has the following problems:
    • Right front passenger door crunched from a side hit
    • Broken left front passenger window
    • Leaking brake fluid
    Am I correct in thinking that I can only sell it for parts, or are there other options?
    The local scrap yard has offered me $450. Can I do better online or elsewhere?
  2. Mendel Leisk
    42,355
    What's your location? What's your insurance situation; has it been assessed? Pictures would help too.
    2010moneypit? likes this.
  3. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Agree with above
  4. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    If it has no other problems, I'd repair it and keep driving. Or maybe someone would buy it from you and repair it? I'm not sure what insurance has to do with this question?
  5. chiropterist
    This car has been rode hard and put away wet by an employee who I found out was using it for things like hauling 500-lb loads of scrap metal. He was also supposed to be maintaining the car, but that didn't happen.
    So after the right door incident I chose not to involve the insurance company because I didn't see the point in paying the deductible to fix a door on a car with so many other problems.
    I don't have access to the car to take pics at the moment, but my mechanic's verdict was "scrapyard".
    I am in the process of buying a used 2015 Prius 3, which NOBODY but me will drive. Ever. Period. I'm just trying to find out how to raise the most cash to put toward my purchase.
    The car is in Rhode Island.
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,121
    6,978
    Texas Hill Country
    A door and a window are easy. A brake fluid leak is pretty easy as well as long as it isn't the master cylinder. Even if you are tired of the car I would fix it and sell for many thousands more than the repair cost.
    mikey_t and bettergolf like this.
  7. bisco
    52,863
    depends on the mileage
    how it has been maintained
    does it burn oil
    how often does the brake fluid pump run
    has the egr circuit been cleaned
    used cars are worth a fortune today
  8. chiropterist
    Thanks for all of your replies.
    Here's the story: I'm driving a 2015 Prius. My question is what to do with the 2011 one pictured here, which obviously won't pass inspection next month.
    Please have a look at the pictures then let me know:
    1. How much I should try to sell it for (the scrapyard offered me $450)
    2. Where I should try to sell it (Craigslist comes to mind)
    As I posted earlier:
    • The car has 126K miles on it
    • It leaks brake fluid and has been driven over a month without any
    • It has been used to haul up to 500 lbs of scrap metal
    • The interior looks about like t he exterior
    • The car is in Rhode Island
  9. Daria Phoebe
    Daria Phoebe Junior Member
    Providence
    The hybrid battery if it's in decent shape might be of use to someone and you could almost assuredly get money for the catalytic converter, after which perhaps scrapyard is fine
    mikey_t likes this.
  10. tallprius
    tallprius Member
    62
    29
    texas
    Premium w/ Solar Cells
    This car has been driving 10 years on heavy salted roads and that could lower value. Yes the battery is worth dollars (if good) but the engine is worthless if it burns oil but how could you know. You could have easy parts removed and sell it for the weight of metal OR fix the brakes if cheap fix and give it to son/daughter to learn how to drive. Why: 1. kids usually tear up the first car 2. a Prius it is a safe car.
