damaged front lip - is there a part # or it's a bumper replacement?
Discussion in 'Prime Main Forum (2017-2022)' started by geguia, Aug 15, 2022.
  1. geguia
    geguia Active Member
    209
    108
    los angeles
  2. Elektroingenieur
    2,515
    3,253
    Three Touring
    Toyota’s catalog has a better illustration: Figure 53-01, Radiator Grille, shows the radiator grille sub-assembly, with part name code 53101. For model year 2017, the part number is 53101-47041 for cars, such as your Prime Premium, without Intelligent Clearance Sonar (ICS); with ICS, it’s 53101-47052. Either way, no paint is required.
    The front bumper assembly isn’t sold as a service part: as shown in Figure 52-01, Front Bumper & Bumper Stay, it’s assembled from the right and left front bumper extensions, the radiator grille sub-assembly, and other parts.
  3. GregersonIT
    GregersonIT Member
    172
    91
    Livermore
    2020 Prius Prime
    Depends how bad it's dented. But that's the grill. To replace it is about 4-5 man hours at most shops plus there is a one-use seal you need to replace each time the bumper is removed.. Make sure that the piece behind it isn't hurt because that can make the difference between 1k and a 2.5k repair at the shop.
