Damaged (?) undercarriage plastic part.
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by ReDave, Jul 23, 2024.
  1. ReDave
    ReDave Member
    82
    25
    Central California, Sierra/Sequoia Foothills
    2019 Prius Prime
    2019 prime, but i'm thinking the under plastic parts are the same?
    I found a shank like piece of metal sticking out from this part, where it created this hole.
    What is this part? I'm hoping it is a protective piece, and not to worry. [it did its job, and might continue]
    It is on the drivers side, under the rear door, in front of the left rear wheel.
    it's dang hot out there, but it does look like there is a part number on this?
    more detailed pictures
    https://photos.app.goo.gl/9ZLBiTwvLnUqWRAX7
    BiomedO1 likes this.
  2. BiomedO1
    BiomedO1 Senior Member
    4,374
    2,296
    Left Coast
    yep, that plastic did it's job.
    Alternatively, if that piece of plastic turns out to be very expensive; I'd clean, duct tape it, then spray liberal amounts and several coatings of flex seal on it. A quick and dirty repair job to keep road debris from accumulating in there that may support rust formation.
    Hope this helps...
    ReDave likes this.
  3. vvillovv
    vvillovv Senior Member
    4,336
    1,517
    NY
    I was going to suggest duct tape too, at least if and until you replace with either used or new.
    This is the best I can do so far. I'm not sure this is the part, but it's at least getting closer than nothing.
    part #'s 76974-47020-C0 or 76974-47020-C1 entering your vin might help, but there are a lot of underbody panels on my 2017 Prime and I don't see much of any of them listed while searching the 2019.
    C0 part
    76974-47020-C0 Genuine Toyota Cover, Rear Under Side
    and the C1 part
    I don't see a diff between the two. It'd be a good idea to get under there when weather permits and pull the part. It makes it a hundred times easier to make sure you are ordering the right replacement. And if it's easy enough getting a used one you'll be sure it's the right one.
    ReDave likes this.
  4. ReDave
    ReDave Member
    82
    25
    2019 Prius Prime
    Thank you guys!
    I'll see if I can get something to cover the hole.
  5. ReDave
    ReDave Member
    82
    25
    2019 Prius Prime
    my vin says it fits, but man, that is one messed up drawing, i assume it's like sideways, thanks for the links!
    vvillovv likes this.
  6. vvillovv
    4,336
    1,517
    NY
    I"d recommend going to a dealer with the damaged part in hand. I"m not sure the link I gave you is the same part as the one that is damaged on your Prime. I'm not sure exactly what's down there, but on my 2017 there are 5 separate panels that attach to the back bumper cover alone.
    The dealer parts counter should have access to the full diagram of all the under panels on your car.
    If you want to DIY the panel replacement the way to get the full diagram is to get a 2 day standard subscription to TIS
    https://techinfo.toyota.com/techInfoPortal
    and look through the repair manual to make sure. ;)
    There's a lot more info available with a 2 day subscription than you need just to replace one silly under panel, but if the part I linked to above is the wrong under panel, I'd be sad and you'd be out at very least return shipping and restocking fee.
    ReDave likes this.
  7. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    I would clean it well, clean up the hole with a file, knife, etc. Then cover the hole with several layers on both sides of the hole with some drywall fiberglass mesh tape ensuring that you overlap the hole by at least an inch on all sides. Then slather Shoe Goo or Flex Seal type rubber products in a tube or can generously over the whole area around the hole.
    The fiberglass mesh will support and strengthen the repair. Then forget about it. :)
    SM-G781V ?
    ReDave likes this.
