damn! stuck on a sheet of ice.
Discussion in 'Gen 2 Prius Main Forum' started by galaxee, Feb 6, 2009.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    So are cats. Position them claws down, facing up the hill.
    Tom
  2. dogfriend
    7,512
    1,190
    Carmichael, CA
    Blind pedestrians would probably be better. More surface area.
  3. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    reagent grade nacl is too pricey for throwing under tires- much better used for various biological buffers, the use of which will get me the hell out of grad school. also, i think the boss would kill me for that.
    i called parking to complain this morning and they threw salt down and made two nice melted tracks for my tires. the ice under the rest of the front end of the car hadn't melted, so i'm glad they did that.
  4. dogfriend
    7,512
    1,190
    Carmichael, CA
    At least you didn't try to kill ants with full strength Nitric Acid like one of the Post-Docs did when I was in grad school. They had to evacuate the lab.
  5. galaxee
    9,810
    471
    MD
    nope, but someone inadvertently attracted them with an open container of sucrose solution!
  6. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Wouldn't nitrogen triiodide be useful to break up the ice?:boom:Or is that just freshman technology?...
  7. patsparks
    10,664
    567
    Adelaide South Australia
    Sodium Chloride does the trick I believe. What lab wouldn't have that? Check the lunch room.
  8. galaxee
    9,810
    471
    MD
    ni3... probably couldn't get it out to the ice before it decomposed! bang!
    pat, the hospital cafeteria might frown upon me going and stealing a salt shaker or 4.
  9. donee
    donee New Member
    2,956
    198
    Chicagoland
    Yikes!
    You know there are not any masks you can wear that are effective against Nitric Acid - got that straight from the 3M Filter Mask 800 number. You need a full Scott AirPack. We had a situation once where passivated stainless steel parts were being cooked indoors, and even the very very small amount of Nitric Acid they were giving off was real nasty. They had to but in a hood over the Ovens.
  10. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    AAwwwwwww that's mean
  11. misslexi
    misslexi Member
    130
    Renton, WA
    I've gotten used to it; I use my snowmobile for the last mile.
  12. dogfriend
    7,512
    1,190
    Carmichael, CA
    Yes, they had to call in the Haz Mat people if I recall correctly. Considering the guy had a PhD, he wasn't really the sharpest tool in the shed.
    I left the lab sometime after that incident - I told my adviser that I was concerned about my safety, but that wasn't the only reason - my adviser was somewhat ethically challenged, and I really didn't want to work for him any more.
  13. essaunders
    essaunders Member
    195
    NH
    I need to get my patent finalized for traction sand injections for Prii. Kinda like railroad traction sand injection, we'd have a reservior of dry sand that could be fed through tubs and deposited in front of / under / behind the front wheels. The traction system would be able to call on this system -- or if you don't trust Toyota TC, we could just put a button the dash.
    The tube would be too small for cat scat, though.....
  14. patsparks
    10,664
    567
    They say the only good cat is a flat cat.
  15. qbee42
    18,058
    3,079
    Northern Michigan
    Do you think this is what the parking lot looked like:
    Actually, I took this photo this evening on the shore of Lake Michigan. This is what the lake looks like now.
    Tom
  16. patsparks
    10,664
    567
    Is that moving or is it solid like that? Please excuse my ignorance.
  17. qbee42
    18,058
    3,079
    Northern Michigan
    This part is solid. Just over the humps are ice caves, and then broken ice which is moving. Here is a look over the top at the moving ice:
    Tom
  18. patsparks
    10,664
    567
    That looks a bit more like what I saw in Chicago although the water looks liquid between the sheets of ice. What I saw looked like a slush on top. It may be the angle of the light in your shot makes the water look clean of slush. I must say the appearance of the partly frozen lake took me by surprise!
  19. qbee42
    18,058
    3,079
    Northern Michigan
    The liquid part is free of slush. It all depends on wind, waves, and temperature. In this case the broken ice was mostly big chunks and not the slushy stuff. In a few hours all could be different.
    Btw, I nearly killed myself getting that photo. For an ice climber, you would think that I would be smart enough to wear crampons, but I was wearing plain old slippery boots. Next time it's crampons and ice axes.
    Tom
  20. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    I heard on the news this morning that on Lake Erie there were about 500 ice fishermen marooned on a broken-off, loose piece of ice.
