Dangerous Driving Technique: Have you tried a rolling restart?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Pluggo, Dec 1, 2016.
  1. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Everyone knows if you breathe too hard the ICE kicks in and won't shut off until the engine reaches normal operating temperature- that is, unless you shut the car off and restart. That's fine when you reach a stop or can safely pull over, but what would happen if a person tried to shut down and restart while rolling? I like to think there is something that prevents the car from slamming into Park and causing a wreck while moving more than 1 or 2 mph. Would shifting to neutral allow a safe shutdown and restart? I am not about to risk this on my own car, and I hope you don't try it either, but does anyone already have actual knowledge or experience about rolling restarts in a PiP?
    52,863
    no experience, but i think if you hold down the power button for 3 seconds, it will shut down.
    otoh, shutting down during the early part of the warm up cycles may cause detonation when restarting.
    uber2016 likes this.
  3. Prodigyplace
    12,716
    11,848
    Central Virginia
    Some people say that shutting down puts the car in Park. Not too good an idea while rolling down the road :eek:
    uber2016 and Pluggo like this.
  4. Pluggo
    608
    534
    Now that you mention it, that sounds like the recommend procedure for an emergency shutdown during a runaway cruise control situation. Of course they don't say much about what happens next, but it shouldn't destroy the car. Also, and I can't find it in the Bible right now, but I read about a 2nd emergency shutdown procedure that involves pumping the start button several times within a couple of seconds.
  5. Prodigyplace
    12,716
    11,848
    Central Virginia
    Page 647 http://www.toyota.com/t3Portal/document/om-s/OM47A29U/pdf/OM47A29U.pdf
  6. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    So you are driving a car that get the best mpg out there and you want to shut it off to save gas? Lol
    repnatl and CaliforniaBear like this.
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    It is worse than that, he it trying to see if he can save more in gas money than it will cost him for a new car.
    repnatl and Prodigyplace like this.
  8. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Since it is bad for the engine to shut it off prematurely after it has already started, even if I could pull over and shut it off, I wouldn't. If anyone is heroic :whistle: (dumb) enough to try a rolling start. Good luck with the locked steering wheel. :eek:
    Prodigyplace likes this.
  9. fuzzy1
    10,713
    That is a new feature added about 2012. It doesn't work in older models.
  10. fuzzy1
    10,713
    With the ignition still turned on, and at highway speed, I have commanded both my Prii to shift to Reverse and Park. No big deal, the car simply overrides by going Neutral with a double-beep audio warning.
    While an approved method of regaining control of a runaway engine / Sudden Unintended Acceleration is to shift to Neutral, I have found that attempted shifts to R or P are quicker. Those choices don't have the delay imposed to an intentional N shift. When practicing, I greatly prefer R because can be done blindly, not taking eyes off the road. The P button is too small to find by eyes-free reflex.
    I haven't tried shutting down the ignition at speed, but doing so is also an approved method of regaining control during engine runaway / SUA event. I've read from others (sorry, link not handy) that the parking pawl won't engage if the car to moving fast enough to damage itself. But at lower speeds where the car can handle it, there is still a substantial jolt to the human inside.
    BTW, I am still unaware of any true confirmed runaway engine or SUA in a Prius outside of floormat-pedal jams.
    bisco and Pluggo like this.
  11. Pluggo
    608
    534
  12. bisco
    52,863
    i am not aware of any confirmed u/a either.
  13. Mendel Leisk
    42,355
  14. Prodigyplace
    12,716
    11,848
    Central Virginia
    How did you do that? Just copy/paste?
  15. Mendel Leisk
    42,355
    If you're on windows 7 and onwards, there's a program called Snipping Tool. Go into start menu and start typing "snip" should find it. I would suggest to right-click the link, choose properties, and give it a hot key (say <crtl> <alt> S), so that you can invoke it with a few key strokes.
    With Snipping Tool you can take a snapshot of any portion of what's on your screen. And if you like there's rudimentary annotate and highlight tools, with erase function too.
    And whatever you have in snipping tool is automatically in Windows Clipboard. If you're in the Priuschat advanced editor (by default in your initial post, or available if you're editing it), once you've got something in Snipping Tool, just position cursor in Priuschat edit window where you want the image, then <ctrl> V will paste it. Or you can save the image, give it a name. Better if you want to subsequently repost or whatever.
    If you have Adobe Acrobat, you can also "print" pages to pdf, then post a single pdf page. Another approach.
  16. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Just Drive It.
    And be familiar with EMERGENCY stopping procedures...but hope you never have to use them.
    And worry a WHOLE LOT LESS about your ICE starting and stopping based on HSD parameters.
    Just Drive It.
    Prodigyplace and Mendel Leisk like this.
  17. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    BTDT numerous times in my Energi. How so?
    If my battery is full, there's no room for regen. I love driving in L gear (this is not like Prius B gear) which gives me a one pedal driving experience; however, it does this partially through aggressive regen. Leaving the house and coming to a complete stop at the end of the block with a full battery sometimes activates the ICE to burn off the excess electricity that the battery can't store. To cancel the otherwise totally unnecessary ICE warmup, I need to power off the car but it has to be in Park. In D or N, I just get an error message telling me to place it in P.
    FWIW
  18. fuzzy1
    10,713
    I don't see a model year attached to that PDF.
    I also don't recall seeing the 'stab 3 times' method in my 2010 manual. I first saw it in my 2012 manual, after the San Diego CHP-Lexus tragedy and others where many panicked (but too short) presses of the Power button did not shut off runaway cars.
    Thus, we must make clear what model years this method works, so drivers of older models don't end up confused or mislead.
  19. Prodigyplace
    12,716
    11,848
    Central Virginia
    That loops like a screenshot from the 2016 manual I posted earlier.
    Good point, though. I forgot this is a Gen 1 Plug-in thread.
  20. Mendel Leisk
    42,355
