Dangling Wire
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ptwardi, Jun 25, 2018.
  1. ptwardi
    ptwardi New Member
    2015 Prius Plug-in
    2015 Toyota PIP... Opened the hood and found this wire dangling. Can't figure out where it could be connected too. Checked all the lights, horn and everything works. Anyone have any ideas? IMG_20180625_094616.jpeg IMG_20180625_094605.jpeg IMG_20180625_094601.jpeg IMG_20180625_094559.jpeg IMG_20180625_094551.jpeg
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    On my 2012 that plug connects to a little blue micro-switch in the hood release mechanism. Standing in front of the car look about 1 inch below the left end of the spring. It pushes in from left to right.
    ptwardi, jerrymildred and bisco like this.
    52,600
    i had no idea, does the car know when the hood is popped?
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    I went a looked, and son of a gun! Mine has one too. I had never noticed it.
    ptwardi and Mendel Leisk like this.
  5. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    No doubt it's for the intrusion alarm. Will set it off if someone forces the hood open without the car being unlocked first.
    Pluggo and jerrymildred like this.
  6. Pluggo
    608
    534
    Yes, I'll vote for the intrusion alarm. Either that or my switch is broken. I just checked and the car goes into gear with the hood unlatched. No warning light displays.
  7. RRxing
    RRxing Senior Member
    2,559
    1,833
    NEPA
    Do your cars have remote start? Looks similar to the remote start wiring when I had my 2010. Remote start wouldn't work if the hood was open, or would kill the engine if the hood was opened after using remote start...
  8. bisco
    52,600
    no. remote a/c though.
  9. bisco
    52,600
    if you pop the hood while the car is on, does it set the alarm, or is the switch set so that only forcing the hood open will set it off?
  10. ptwardi
    ptwardi New Member
    2015 Prius Plug-in
    Thank you guys!! I found the blue switch on the hood latch. I would have never thought too look there.
  11. ptwardi
    ptwardi New Member
    2015 Prius Plug-in
    jerrymildred likes this.
  12. RRxing
    2,559
    1,833
    NEPA
    But what is it for?
  13. jerrymildred
    11,517
    14,164
    Tampa, FL
    I am guessing, but the only logical guess I can come up with is the same as @Pluggo. It's part of the alarm system.
    I think that because I have had the hood open gobs of times with the car in READY and never saw any indicator lights.
