Daox's Enginer PHEV 4kWh install
Discussion in 'Prius PHEV Plug-In Modifications' started by Daox, Dec 24, 2009.
  1. linuxpenguin
    linuxpenguin Active Member
    352
    182
    No that's probably about right (depends on the voltage that the OEM pack is)--it should be putting out around 2.3 kW (10a * 230v) so if you have a 4 kWhr system...
    Andrew
  2. dan2l
    dan2l 2014 Prius v wagon
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hello Andrew,
    I am sorry, I have no idea what you are talking about. You statment does not match to the quote from Doax.
    Thanks,
    Dan Lander
  3. linuxpenguin
    352
    182
    I was responding to the last part about the pack depleting over a long period of time...
    Andrew
  4. dan2l
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hello Doax,
    I would encourage you to get a Clamp-on DC ammeter. Sears has one for $60.
    You can see in this image the Ammeter shows 13.78amps. This is a much better way to see when you close to the end of charge.
    Thanks,
    Dan
  5. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    That's fine for doing a bench test. Do you know of anything that could be used to monitor amps while driving?
  6. dan2l
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Andrew,
    So you have no way of knowing that Doax's system is outputing 10a at 230v. He has not measured that. I think Doax is indicating that he thinks he may be getting lower output over a longer distance. That may be true but we wiil not know his output until he measures it.
    My system is giving 10a at 245v. I will have an idea of how long this will last with-in a day or two.
    Thanks,
    Dan
  7. Daox
    Daox Member
    196
    58
    US, Wisconsin
    A 100A ammeter and shunt.
    Unfortunately I don't have one on hand. I'll ask the guys in the EV club if anyone has a spare laying around.
  8. Daox
    Daox Member
    196
    58
    US, Wisconsin
  9. dan2l
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
  10. Daox
    Daox Member
    196
    58
    US, Wisconsin
    I agree the clamp meter would be easier to use for charging, but I was actually replying to MJFrog's question about monitoring it while driving. It would be interesting to see how consistent the amp pull from the pack is while driving.
  11. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    I got two similar items from a ebay seller but the ones I got can measeure Current and Voltage. One is 500V and 200A for the DC converter to OEM battery. One 200V and 200A for the Battery to Converters. Both included a 200A shunt. I will post pictures once I install in my car. But using a clamp type meter would not be very ideal for tracking current while driving.
    Here is the ebay item I got : http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180451161867
  12. pbui
    pbui Member
    190
    Los Gatos, northern CA
    sorry, it got deleted somehow; let's try again:
    -Paul
  13. pbui
    pbui Member
    190
    Daox,
    what was the cell voltage from each balancer ?
    thanks
  14. dan2l
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Paul,
    I had a similar concept using all of the 3rd balancer.
    I guess great minds work along the same path.
    Thanks,
    Dan
  15. mrbigh
    3,686
    699
    Long Island, NY
    Well, this is the real story in battery fuel gauge and does require a shunt(provided) in line, a real electrical instrument. Inclusive there is a version of this meter that will output serial information to a PC if needed. This instrument is a land mark for EVers and is known also as a "E-meter". The Mickey Mouse clamp meter is effective only in bench and stationary and local reading, but some people are purchasing what they can and know. This "instrument" is not cheap but it warrants accurate results.
  16. Daox
    Daox Member
    196
    58
    US, Wisconsin
    By the time I had it apart (the wife actually uses the Prius as a work vehicle and hauls stuff with it) the voltage had settled. You really can only measure voltage under load (with any battery AFAIK). As a battery sits the voltage tends to increase, so measuring resting voltage is very deceiving if you are looking to see how much of the pack capacity you used.
  17. Daox
    Daox Member
    196
    58
    US, Wisconsin
    nothing! :)
  18. dan2l
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Doax,
    I regularly check the balancers during charging. I am seeing one or two cells climbing higher than the others while charging. They can get 200mv out of balance when the charger is pumping 6 amps. Then as the charger curent drops to 3 amps or so the umbalance gets better. Once the charger is off, the balance quickly goes down to 20mv or better. I watched on cell go to 3.72v today and then go back down quickly when the charger stopped.
    Thanks,
    Dan
  19. pbui
    pbui Member
    190
    Dan,
    have u wired it up ? did it work ? you mention that you regularly monitor the cell voltage in your other reply; are the cell voltage different between separate balanced pack ?
    I hope once Jack & Chargery come up with the new 16-cell balancer, they'll send us some. I also suggested to Jack to automate the top/bottom (charging/discharging) balancing using the DB8. I think he's considering it as he has not responded given that he is usually quite responsive.
    ps: not sure if my mind is great, but it works for me. I just have to remember to use it ;)
  20. Jay C
    Jay C Member
    72
    36
    TN
