Dare Try The Future | Nanoparticle Engine Oil Additive
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PRIUS STAR SHIP, Apr 23, 2017.
  1. PRIUS STAR SHIP
    PRIUS STAR SHIP Junior Member
    34
    17
    Interesting New Product:
    More Info At Indiegogo & At TriboTex
    Let The Comments Begin Below:
  2. Rmay635703
    Rmay635703 Senior Member
    2,674
    1,703
    Somewhere in Wisconsin
    2013 Chevy Volt
  3. TomWA
    TomWA Junior Member
    Wenatchee, WA
    2001 Prius
    Does anyone tried it? I am highly curious. The science seems interesting and they did got a lot of money from government for the research.
  4. Rmay635703
    2,674
    1,703
    2013 Chevy Volt
    I tried a very similar additive years ago and my timing chain channels got sludeged and the chain failed, luckily I caught it early enough but I had to have an engine flush and chain replacement.
    Modern cars can’t really use this type of additive unless they are very worn out, these additives really only work on 1980’s and older tech with their larger oil passages.
    Robert Holt likes this.
  5. TomWA
    TomWA Junior Member
    Wenatchee, WA
    2001 Prius
    Rmay, in what way similar? Nanoparticulates? Government funded? or from Kickstarter? Maybe you remember a name?
    My 2001 Prius just got battery replaced with new second gen cells and despite 205,000+ miles on it running strong but engine rattles giving away its age.
    I am still curious will it work for my ride? Reviews seem positive but want to know any Prius-specific experience. Anyone here?
  6. Rmay635703
    2,674
    1,703
    2013 Chevy Volt
    Anything that hawks a single product with reviews or a testimonial on the front page is a scam.
    No further reading necessary.
    All of the above, developed for NASA
    Qx700 and moly addictive
    If you want snake oil the only two that work and are harmless are
    Qx-500 and MMO , MMO in fuel actually increased my compression results on a water scored 3.8 Buick .
    So both above work and are harmless, everything else “nanoparticle” I would avoid
    #6 Rmay635703, Feb 12, 2018
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Instead of additives use higher quality oil. One with zddp. Our cars use solid lifters which is why there’s so much valve noise. Zddp is an excellent remediation for that. I run Redline oil the engine is 100% smoother.
    I also use Redline D6 atf.
    Google. Redline oil reviews
  8. RRxing
    RRxing Senior Member
    2,558
    1,833
    NEPA
    I turned off the video after "Returns the metal to better than new..."
  9. potatoesLOL
    potatoesLOL Active Member
    145
    413
    Downtown Los Angeles
    Sorry to revive an older thread lol. I’m curious to see if anyone has tried TriboTEX.
    TriboTEX Oil Additive Car Engine Treatment: Add to Engine Oil - Makes High Mileage Cars Like New with a Synthetic Material (Treats One Regular Car, Truck, Tractor or Small Diesel)
  10. bisco
    52,543
    only the gullible...
    potatoesLOL likes this.
  11. TomWA
    TomWA Junior Member
    Wenatchee, WA
    2001 Prius
    Ok I ordered two small ones for my Prii from Amazon will see what results are!
    Grit likes this.
