Darell's first Prius journey and...
Discussion in 'Gen 2 Prius Main Forum' started by darelldd, Feb 21, 2006.
  1. aaf709
    3,862
    2022 Prius Prime
    Neither have I, but I understand it does something like dropping into neutral, not a sudden stop.
  2. darelldd
    6,059
    389
    Northern CA
    If they haven't made that failsafe, I'd be seriously concerned. I have so much confidence in Toyota that I'll even volunteer for this test. Stay tuned later in the week when my Prius comes back (my wife currently has it at work out of town).
    If you don't hear back from me, I'm probably dead, and don't recommend anybody else tries it.
  3. kdmorse
    kdmorse Member
    205
    Germantown, MD
    *cough*manual*cough* :)
    At speed, just pressing Power does nothing, its ignored. When held for 3 seconds, it shuts down the HDS, flips into IG-On (or was it ACC), and drops the car into neutral (not park). You loose power steering, and are left with non-power friction breaking. I don't believe the car can be restarted until you have come to a complete stop.
    At low rollings speeds (a few mph), it may be a jarring stop, just like pressing P at a few mph is. But at any speed that would hurt the transmission, it just slips into neutral.
    -Ken
  4. darelldd
    6,059
    389
    Northern CA
    Again!?
    OK... but this one wasn't my question! :)
  5. kdmorse
    kdmorse Member
    205
    Germantown, MD
    And before someone asks....
    If you shift from Drive to Reverse, or Reverse to drive at >10MPH, it just drops into neutral.
    If you do it at less than 10mph, now it's just neat. Because of the motors and the CVT, it's a 100% smooth transition. While rolling backwards, if you slip the car into drive and press the pedal, your forward acceleration gently reduces your reverse speed, until you cross 0mph, and then accelerates you forward. Same for the opposite direction.
    Considering the amount of work required to intentionally lock your keys in the car, did you really believe they'd let you drop the transmission into Park at 80mph? :)
    -Ken
  6. darelldd
    6,059
    389
    Northern CA
    Well, no. But I could tell that some were sort of hoping....
  7. darelldd
    6,059
    389
    Northern CA
    It is my sworn duty to imform you that the manual SPECIFICALLY says NOT do to this. This part I remember, for some odd reason. Says to ONLY shift into the other direction after the car is completely stopped. Like anybody ever does that with ANY trans...
  8. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    im sure it did disappoint a few people... think of being able to squeal rubber without the telltale engine revs...
    definitely worth seeing an unsuspecting pedestrians face.
  9. darelldd
    6,059
    389
    Northern CA
    Dave. I have two letters for you: EV.
  10. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ya, i saw Dr. Franks video with the EV chevy surbuban...pretty awesome
  11. jonabbey
    jonabbey New Member
    Austin, TX
    Yeah, my question. :D
    I did read the manual, start to finish, but there's a lot of stuff in there that's repetitive (how many times do they mention the phrase 'death or serious injury' in the 2006 owner's manual for the same action?), and I was looking mostly for neat features I didn't know about.
    I'm terribly impressed with the Prius so far, and I could not conceive of the car doing something bad with a press on the power button, but I figured someone had actually tried it.
    I remember when I was about 9, driving with my dad in our automatic transmission 1976 Chevy Nova. I was bored in the passenger's seat and wondered what the lever with the big button on it did, so I pushed in the button and shifted the car into park.. while we were travelling at about 15 mph.
    My dad told me that if I had pushed it a bit farther, into reverse, the engine would have leapt out of the hood. :lol:
    Anyway, I'll be sure not to press and hold the power button long enough to see what happens when the car goes into neutral at speed. ;)
  12. darelldd
    6,059
    389
    Northern CA
    Ah yes. When I was three, I drove my grandpa's Caddy into a brick wall at 2mph by pulling the tree shifter into drive while he was out opening the gate. Was great fun for me!
  13. Tideland Prius
    16,675
    Good place for a summary of the mods. Thanks!
  14. benighted
    benighted New Member
    530
    Westport, WA
    I've noticed the same thing about the Prius tail lights. A while back I was driving at night and came up on a car that I noticed had really dim tail lights, sure enough it was a 04+ Prius, I was kind of surprised actually.
  15. darelldd
    6,059
    389
    Northern CA
    It is one of the few tail lights I've seen where there is a cap on the bulb to prevent directly lighing out the lens (many headlights are like this to reduce glare). I'm not yet sure what wattage of bulb is in there, but for my money it isn't quite up to the task. Not only are the lights somewhat too dim, but they're also quite a bit smaller than you see on most modern cars these days. Many cars will light up a couple of bulbs, and that makes for more red realestate back there.
  16. dprius
    dprius New Member
    Couple of qs for you. You said "EV mode...
    1. I LOVE this, and am glad I installed it before the car was 12 hours old. :)" What is it you installed? I looked through the manual and the Toyota web site and could not find anything about "installing" and EV mode?
    The plastic rims on the wheels - what interference do they cause? What value is there in removing them?
  17. aaf709
    3,862
    2022 Prius Prime
    Well, the EV mode is something that isn't available in the US or Canada, but is in Japan and Europe (which is why it isn't in the manual). The EV mode will, under the right conditions, make the Prius run on battery power alone for about a mile or so. Handy to move the car in a parking lot or to show off. Used right you can save a bit of gas, but remember the ICE will have to run to charge the battery back up. There are several ways to activate it (the software is in the car, but the button isn't) from the OEM switch to using an existing control (such as the headlight flash or cruise control). A search on EV MODE will answer some questions (and bring up others).
    As for the rims I haven't removed them yet, but it does change the appearance.
  18. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    They pop on and off real easy... no tools necessary.. just reach up and grab the other ring from the center out and pull... I like mine better on....
  19. darelldd
    6,059
    389
    Northern CA
    Howdy dprius -
    Any chance we could get you to NOT quote my entire opening post?! That thing's huge, and I don't think anybody needs to read it twice! You can go back and edit that post, and just take the quoted part out... thanks!
    If you look at the Prius link in my sig, and then choose "mods" you'll see "EV mode" in there somewhere. You can follow those links for modification instructions.
    The plastic wheel rims don't interfere with anything... except the good looks* of the factory wheels!
    * your mileage may vary.
  20. Begreen
    Begreen Member
    670
    Western WA state
    Yes, I followed a Prius tonight and you are right, next to the other cars, the Prius taillights were noticeably dimmer. Can the bulb cap be removed or scraped off?
    PS: What did you do to show your GreenHybrid mpg? When I tried in my sig, all I get is the URL.
