Dark display on 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CaptBob, Sep 22, 2013.
  1. CaptBob
    CaptBob Junior Member
    Has anyone tried any modifications and/or additions of LEDs to brighten the Prius display. It the glaring Florida sun, the display can be almost impossible to read.
    I would appreciate any comments.
    Capt Bob
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    No doubt made worse by wearing sunglasses. I have polarized lenses in mine which makes the MFD display pretty much unreadable.
    I actually prefer to drive around with the display turned off. The display does come back on whenever it needs to such as after a volume adjustment is made.
    You are referring to the MFD screen and not the dash illumination, right?
  3. Curtis V Harrison
    Curtis V Harrison New Member
    Saratoga Springs, UT
    Technology AWD-e
    There is a dimmer switch to the left of the steering wheel just above where your left knee would be when you're driving. It's a thumb wheel that you can spin up or down to brighten or darken the main display and all the LED displays as well. Crank it all the way to the top for max brightness.
    52,849
    my dimmer switch fell out, and now the it just keeps getting dimmer. does anyone know how to put it back in?(n)
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Is it mounted to instrument cluster panel on lower left of driver? You should be able to snap it back into place, they can be unsnapped and relocate to another panel port.
  6. bisco
    52,849
    thank you :)
    Grit likes this.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Did that work out?
  8. bisco
    52,849
    perfect!(y)
    Grit likes this.
