Darker tailights on some Priuses
Discussion in 'Gen 2 Prius Main Forum' started by rpiereck, Mar 28, 2008.
  1. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    The darker upper tailights get their darkness from the inside black plastic (and not from the outside lens which is clear).
    I don't think Toyota Parts sells the 04-05 inside black plastic piece by itself. You'd have to buy the entire 04-05 tailight assembly for about $180-$200 each.
    If I wanted to make mine darker, I would probably just try spray painting it first.
    Another possibility is to just tint the upper part of the outside lens. But that would cut down the light emitted (what light is that anyway?).
  2. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    It's full of reflectors for the backup light which gives directional light for the backup camera. (I'm 85% sure of it).
    EDIT: and I'm 85% wrong too. I just checked and the upper rear lights are simply reflectors for the red brake lights.
    Whew, glad that 15% doubt was there.
    ZC1
    (Also I'm talking about a 2008 model)
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    what!!!???
    the top tail lights are LEDs. there are brake lights! 6 RED LEDS on each side sit on a horizontal plane. they shine up and then that 45 degree shiny piece reflects through the rear of the lense.
    the blinker is under the stop lights (yellow bulb)
    the rear back up lights are under the turn signal (clear bulbs)
    and the running lights are on the bottom. (red bulb)
  4. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    ebay is your friend!
    but is there a reason the link will not copy over?
    eh, just search prius tail light... i saw 2 sets of the 04-05 lights there.
  5. Boo
    5,051
    483
    97
    Flushing, NY
  6. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    I just noticed this on mine too! It’s an ‘04, it survived all this time until the end of summer here & now this.... I already have some replacements off an ‘07 since the right one had a flaky LED.
