Dasaita Android head unit: reverse camera question
Discussion in 'Gen 4 Prius Audio and Electronics' started by FiremanNZ, Apr 11, 2021.
  1. FiremanNZ
    FiremanNZ New Member
    NZ
    Well, I have a Dasaita Android head unit, this one:
    Everything works, steering wheel controls etc - everything except the reverse camera.
    The camera works and has power, and if you feed the signal to the aux video input, you can see the camera video.
    The reverse selector works, and sends the correct signal to the head unit, this has been checked and measured; when you put the car in reverse, it sends the signal to the head unit.
    The head unit just doesn't DO anything with the signal! With the camera connected to the reverse camera input instead of the aux input, the camera video is never displayed when you go into reverse. The unit just carries on as if reverse had not been selected.
    Any suggestions? Is there some setting in the options I might have forgotten to set, or need to change to make it work?
    Thanks!
    Mike
  2. kc5dlo
    kc5dlo Active Member
    266
    164
    DFW TX
    2021 Prius
    I started to tell you to hook the camera to the aux video where you tested it and supply voltage to the camera from tapping into the back-up lights. Thats what I had to do with my 2014 EXCEPT, I had to replace the factory 6v camera with an aftermarket 12v camera. I am pretty sure the unit you have accommodates the factory camera.
    Maybe try sending a note to the company you bought it from? Sometime they are very knowledgeable.
  3. Mohibullah Mamun
    Mohibullah Mamun New Member
    Dhaka
    I have prius 2017. Head unit DSZT-YC4T.
    I had (had because I don't see this now) dynamic reverse steering help. So when I went to reverse mode the steering help automatically showed the way the car will go once I make turn to my steering. It showed the path I will be going.
    But may be from somewhere I turned it off mistakenly and trying very hard to find it again. Can you help?
  4. kc5dlo
    266
    164
    DFW TX
    2021 Prius
    I suspect that that feature would be lost with a head unit swap
