Dash buttons not working 2010
Discussion in 'Gen 3 Prius Audio and Electronics' started by Fxnhercar, Feb 28, 2026.
  1. Fxnhercar
    Fxnhercar New Member
    RI
    The dash buttons, surrounding the touchscreen, are not working. touchscreen was replaced and works, steering wheel buttons work. Anyone have this issue and/or a solution?
    Thanks in advance, Johnny
  2. ASRDogman
    ASRDogman Senior Member
    8,023
    4,072
    Perhaps whoever replace the touchscreen didn't reconnect a connector? I know they are small....
    Fxnhercar likes this.
  3. Fxnhercar
    RI
    They weren't working well before. And i don't know if the touch screen would control dash buttons. I would imagine the opposite
  4. ASRDogman
    8,023
    4,072
    "he dash buttons, surrounding the touchscreen, are not working."
    Since you mentioned the touch screen, you must have ment the "dash" buttons
    the ones surrounding the radio.....
    So what dash buttons are you writing about?
  5. Fxnhercar
    RI
    The physical, hard buttons that surround the touch screen but not the touch screen itself. I'll take a picture when I get home
  6. ASRDogman
    8,023
    4,072
    If they were working before the touch screen replacement, then a cable is either not connected,
    not connected correctly, or it got damaged during the screen replacement.
  7. Fxnhercar
    RI
    These buttons are not working. Some were not great before touchscreen replacement but all have worsened til none are working.
  8. ASRDogman
    8,023
    4,072
    Then I would "guess" that there is a defective cable.
    Or dirt is the buttons or connection.
  9. mavisleonard
    mavisleonard Junior Member
    los angeles
    have you tried replacing fuses? cheap way to begin troubleshooting. There are fuses under the hood, but also in the car to the left of the steering wheel. it is easy to find fuse diagram online. mine is 2011 prius
