dash cam power from windshield mirror?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by avram, Jan 6, 2017.
  1. avram
    avram Junior Member
    california
    Hi. I'm thinking of getting a dash cam, but don't want to run a long cord along the windshield to plug in cigarette lighter under the dash.
    My 2005 Prius comes with some fancy mirror has a connector with a couple wires plugged into it.
    Has anyone successfully powered a 5-volt device like a dash cam from the windshield mirror plug?
    I found youtubes describing which color wire to connect to +/-, but none of them are fora prius.
    Maybe via a 12v to USB adapter that can be taped behind the mirror?
    Thanks
  2. MTIan
    MTIan Junior Member
    Bozeman, MT
    I would love to know if anyone has insight!
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    you should be able to tap into the dome light hot wire, but how much current does the dashcam draw?
  4. MTIan
    MTIan Junior Member
    Bozeman, MT
    Mine draws 2-3 amps
  5. 69shovlhed
    2,170
    748
    Delaware
    I would think that if you switched to led bulbs (not the super bright bulbs) in the dome light, you could add the cam with no chance of popping the fuse. most likely you would be ok without using leds, but small t10 bulbs will draw less amps than incandescent bulbs.
