Dash cam power tap from rear view mirror?
Discussion in 'Gen 3 Prius Technical Discussion' started by DS Justice, Jun 29, 2018.
  1. DS Justice
    DS Justice Junior Member
    16
    bc, canada
    So I've finally acknowledged the need for a dash cam. It seems like a waste of time and effort to pull power up the A-pillar when there's switched +12V already at the mirror to power the (unused) garage door remote buttons and backup camera.
    Anyone that has added a power tap to the rearview mirror on a Gen 3:
    How bad was it? Any major gotchas?
  2. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Raytheeagle likes this.
  3. DS Justice
    16
    bc, canada
    Thanks! I searched, didn't find any in this forum about tapping the mirror. The sienna one looks helpful, thanks.
  4. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    There is constant power at the vanity light in the headliner. There is switched and constant power in the overhead console - just meter out the harness plug for the little overhead console. I stole constant power from the map light for the Homelink buttons in the rear-view mirror and switched power from the overhead for my auto-darkening in the rear-view mirror.
  5. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    Tim,
    Do you have any more info on what you did with the Homelink buttons and auto-darkening mirror?
  6. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I pulled the overhead console and tapped into its harness after testing for constant and switched power. Tight squeeze, but not difficult
    LG-H810 ?
  7. bobzchemist
    507
    342
    OK, thanks. What was the advantage to switching the auto-darkening mirror to constant power?
  8. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    The mirror got switched power
    LG-H810 ?
  9. B.R.
    B.R. Member
    Menlo Park
    Thank you! I will not route a wire around or poke around anywhere near the airbags. Using switched power reduces the risk of draining the 12v battery when parked a long time. What's the current limitation on the mirror? Do you need all 3 parts shown in the link?
  10. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    First of all, sorry I don’t know the current/amperage limit of the power/homelink mirror, I just tapped into it and assumed my dashcam won’t cause a problem or blowin fuses.:p
    On the link I posted, I followed the instructuon to install dashcam in my Sienna (hints why linked from SiennaChat), but since this USB cable/tapping pin isn’t available any more
    , I bought this instead -
    and asked a friend of mine to solder paper clips to the ends as tapping pins, so I can just push the pins into my homelink mirror circuit for switched power and ground. Been running this setup on my Sienna for 9 months and no problem at all. (y)
