Dash Cam Recommendations
Discussion in 'Prius c Accessories and Modifications' started by Tony Zenmaster, Mar 15, 2016.
  1. Tony Zenmaster
    Tony Zenmaster Junior Member
    Garden Grove, California
    Hi guys. Does anyone know a good dash cam they can recommend? My Prius C got dented over the weekend by a motorcycle whose rider took off. I'm in the market now for dash cam. Preferably one that can record license plates clearly.
    PriusC_Commuter likes this.
  2. djdawn
    djdawn Active Member
    255
    115
    Escondido, CA
    2014 Prius c
    Sorry to hear bud. I know the feeling and eventually went nuts with the dash cam idea. I have this for the front camera:
    DriveEye High definition 3mp dash cam vehicle recorder US
    It doesn't block much of the windshield, video quality was clear, 1080p record, as well as wifi if you care.
  3. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    306
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    I've been thinking about getting a dashcam for quite some time now, looking forward to seeing what others recommend. Ideally I'd like something that doesn't stick out too much so it doesn't attract thieves. I thought about the BlackVue models, but they are a bit pricey.
  4. contravox
    contravox Junior Member
    New Haven, CT
    2015 Prius c
    Pardon me for asking, but how did a motorcycle dent your car?
  5. Tony Zenmaster
    I was stopped at a red light, motorcycle behind me tried to split the gap between me and the car next to me. Gap was tight, so a part of his bike dented my wheel well.
  6. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    I use an A118-C. Very reasonably priced at $52 on gearbest.
  7. Bigboi
    Bigboi Member
    136
    25
    Las Vegas
    2015 Prius c
    Can you post where you mounted it because the Prius C has these black dots on the windshield near the mirrow so if the A118-C was mounted there it'd have black dots blocking it's view. Also if you use the car lighter socket, how do you charge anything else besides the super slow charging USB port near the aux in?
  8. firstrival
    firstrival Member
    100
    G1W-C with a mirror mount.
    PriusC_Commuter and Bigboi like this.
  9. se-riously
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    Just make sure the lens is below the black dots. I use a 4-USB socket charger that plugs into the car lighter socket. To power the camera, you can use a USB to mini USB cable.
    Bigboi likes this.
  10. Bigboi
    Bigboi Member
    136
    25
    Las Vegas
    2015 Prius c
    The camera doesn't need the lighter socket adapter to charge it? It can work/record with just USB cable to USB port in the car?
  11. se-riously
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    This is a capacitor based model, so no battery to charge (or heat up or catch on fire). It only works when the USB powers it.
    Bigboi likes this.
  12. Bigboi
    Bigboi Member
    136
    25
    Las Vegas
    2015 Prius c
    That's awesome, really good to know. I will definitely look into getting one of these!!
  13. Topp Cat
    Topp Cat Member
    71
    66
    Most of the 1080 do a good job. Check Amazon feedback and reviews I installed front dash and rear hatch camcorder this weekend. Wires a 12v outlet to the back.
    Bigboi likes this.
  14. thetakara
    thetakara Junior Member
    36
    I have a Vicovation Marcus 3. Works excellent for me.
Loading...
