dash cluster 2012 Prius
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Anthony J Nazzaro, Jan 11, 2013.
  1. Anthony J Nazzaro
    Anthony J Nazzaro New Member
    While driving along everything on the dash speedo gas gage all black only shift indicator was on, the next morning as I was driveing everything went back to normal is this something everyone or someone has had happen to them
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Do you own a 2012 Prius liftback or a 2012 Prius c. Your profile states liftback but you posted in the Prius c forum.
    Did you somehow rotate the dimmer switch, that can cause the gauges to dim to off and on.
    RocMills likes this.
  3. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    If you have the liftback and not the Prius C, the speedometer is part of a heads up display. If a piece of paper, business car, etc lays on the dash just in front of the speedo, the display disappears.
