Dash cover to keep it cooler?
Discussion in 'Prime Accessories and Modifications' started by 1x1, Aug 1, 2017.
  1. 1x1
    1x1 Member
    147
    45
    One of the first things I noticed about my Prime (versus my 2nd Gen Prius) is how hot the dash gets. Sure, the AC works great, but on a hot day I can really feel the heat from all that black plastic. And I don't always want to use AC.
    I've never purchased a "dashboard cover" before. They look like a cheap, thin carpet. But I'm wondering if they help prevent the heat build up?
    Anyone have success with one on the Prime? Care to share the vendor/link? Thanks!
    (Apologies in advance if this has already been discussed. I searched the "Prime Accessories and Modifications" and "Prime Main Forum" forums.)
    Bonobo.P. likes this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Tyfly, WilDavis and 1x1 like this.
  3. 1x1
    1x1 Member
    147
    45
  4. jerrymildred
    11,517
    14,164
    Tampa, FL
    True dat!! :ROFLMAO: But probably no more so than the texters who surround me every day. :confused: People here don't usually look up till they hear the big bang anyway.
    1x1 likes this.
  5. huskers
    huskers Senior Member
    2,546
    2,488
    Nebraska
    You might be able to cut a couple peek holes in it. Or just drive at night or when cloudy.
    jerrymildred likes this.
  6. 1x1
    1x1 Member
    147
    45
    Yes, often the first ones waiting at the light are the last ones to see it change to green...
  7. AnneLW
    AnneLW Member
    118
    95
    California desert
    Anyway has anybody found a dashboards cover that fits?
    Having one on my 2004 really helped.
  8. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I have a sun-shield for the front and also one for the rear and they work beautifully. Definitely to be recommended! :)
  9. AnneLW
    AnneLW Member
    118
    95
    California desert
    I'm sure everybody has windshield screens.
  10. bodgm
    bodgm Junior Member
    58
    US
  11. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    NO !!
    Once the sunlight (infrared) gets into the car, it is going to heat up SOMETHING.
    The reflective covers installed as close to the glass as possible help some.
  12. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    You'd have to cut out an opening for where the HUD projects onto the windscreen. I second the suggestion of the foil widow shades - front and rear since the rear hatch window makes a great solar heat collector right over the battery.
  13. RoxD
    RoxD New Member
    2020 Prius Prime
    Do they make a rear hatch sun shade for 2020 PP XLE's? Also, I thought a dash mat helps to protect the dash from drying and cracking over time.
  14. Chazman62
    Chazman62 Member
    108
    66
    Long Beach, CA
    2020 Prius Prime
    Yup, lots of heat comes through the LARGE (37" tall) windshield which is probably the tallest in its class (classified as compact) and still taller than that of many other larger cars and trucks.
    Nanz likes this.
  15. Chazman62
    Chazman62 Member
    108
    66
    Long Beach, CA
    2020 Prius Prime
    I got my hatch window tinted and it helps quite a bit blocking the sunlight.
