Dash Dimmer activates voice and radio on 2017 prime advanced
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Toyota Chris, Apr 7, 2024.
  1. Toyota Chris
    Toyota Chris New Member
    Cascade, ID
    A suite of problems started suddenly as I was driving down the road one sunny day. The voice command started to come on by itself and asking me to say a command, repeatedly. When this started, the radio also started turning on by itself, switching the source randomly, and sometimes increasing or decreasing the volume to max or min. My wife figured out that turning the dashboard dimmer light all the way down stops these problems. As soon as the dimmer is turned up even one step, the problems resume. I tried swapping out the steering wheel control switches and the dash brightness/parking assist/vehicle control system switch, with no change in symptoms. My next guess is to swap out the wiring harness, but I haven't figured out if it's the whole upper dash instrument panel harness or a different harness. Is it likely to be the harness? Does anyone know the part number? Any other ideas? Thanks for any help!
