Dash disassembly help
Discussion in 'Generation 1 Prius Discussion' started by Rabbi, May 8, 2021.
  1. Rabbi
    Rabbi Junior Member
    25
    Garden City, Kansas
    Anyone have a step by step for removing the dash on a Gen 1? I'm working to replace the immobilizer.
    Thanks
  2. ChapmanF
    19,042
  3. nimblemotors
    nimblemotors Re Member
    117
    37
    Sacramento
    2002 Prius
    As I recall you pretty much have to disassemble the entire car..I've dismantled a few of them and I can't imagine doing it being careful and then reassembling it all again. I just cut into the dashpad above and then it is easy to get to it. Using a vibrating cutter can make somewhat clean cuts to glue it back together, one of my cars had a dashpad already, so hidden, the other was junky car anyway..
    It is possible to get to it from below, probably need to fashion a tool with a camera
  4. ChapmanF
    19,042
    Art's Automotive has described replacing that without removing the dash (or cutting it up, either). Apparently your arm looks like this afterward, but it's possible.
  5. Rabbi
    Rabbi Junior Member
    25
    Garden City, Kansas
    I appreciate replies. I am likely going to use the cutting tool. I had watched the video from Art's Automotive and still couldn't find the ecu up in there. I am happy to cut it and tape it. :).
  6. Sohaib Alarabi
    Sohaib Alarabi Junior Member
    JORDAN
    2001 Prius
    Ive been looking for tips about dismantling it and ive found out it has 4 main fixations other than the plastic on the sides...
    Couple of 10m nuts beneath the odometer button pad ..and couple of 8m bolts beneath the weather control knobs
