Dash display blank, car won't turn off, hatch won't open!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by danielac86, Sep 28, 2018.
  1. danielac86
    danielac86 Junior Member
    Saint Petersburg
    I
    Hi everybody,
    I woke up this morning and when I drove my 2006 Prius with ~170k miles, a few things went wrong:
    -dash display (speedometer, odometer, etc.) wouldn't turn on
    -the touch display worked fine but wouldn't show fuel consumption
    -the car would not turn off, eventually it did turn off normally but the second time I drove it I had to hold the power button and then double tap
    -the hatch would not open (using key fob, hatch button, or driver's side unlock button) with the car on, but when I turned the car off and unlocked it the hatch would open
    I'm hoping these are all symptoms of one problem since they started at the same time. Any suggestions would be greatly appreciated.
  2. tim zheng
    tim zheng Junior Member
    16
    new york
    combination meter repair
  3. Prodigyplace
    12,720
    11,852
    Central Virginia
  4. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    Hold power button down for 3 or four seconds. The car will shut off though your center display may still be on. If it is, press the power button three times quickly ( without your foot on the break pedal, you can have the emergency break on)
    That will shut everything down
    iPhone ?
    davecook89t likes this.
  5. exstudent
    exstudent Senior Member
    2,214
    906
    Torrance, CA
    Contact Matt at Texas Hybrid Batteries. He sells repaired ComboMeters.
    He has a GOOD reputation here, and is a legitimate business! No ScamList (Craigslist) hack.
    Texas Prius Battery Replacement
    Paul Schenck and jerrymildred like this.
  6. Prodigyplace
    12,720
    11,852
    Central Virginia
    His combo meter link is in post 3
    jerrymildred likes this.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Dittos on the recommendation to contact Matt.
    Paul Schenck likes this.
  8. Novel
    Novel Junior Member
    Since I'm having all the same symptoms, I wondered what you ended up doing to correct the problem.
    Since I'm having all the same issues, I wondered what you ended up doing to fix the problem.
  9. bisco
    52,889
    replaced, repaired the combo meter
