Dash display dissappeared
Discussion in 'Gen 3 Prius Main Forum' started by Peter M Evans, May 17, 2019.
  1. Peter M Evans
    Peter M Evans Junior Member
    Sweet Home, OR
    The trip, battery display just went out. The rest of the dash works, MPH, Gas gauge, etc. The only part out is the display controlled from the steering wheel. Any ideas on repair? Or to the dealer I go?
    52,873
    could be a bad combo meter
  3. rsgillmd
    rsgillmd Junior Member
    38
    Memphis, TN
    Did you jump start your car before this happened by chance? I had to jump mine recently and noticed the same thing. I shut it off and reinspected and realized I hadn't pulled down the cover for the positive terminal that flips up. When I flipped that down and restarted it was fine.
  4. Peter M Evans
    Sweet Home, OR
    No I wish it were that easy. They say the combo meter is bad. $1300 for the part alone and it is a remanufactured one. Is this one of the meters with a bad solder connection
  5. bisco
    52,873
    yes. you should be able to find one cheap. check with texas hybrid batteries, or auto be yours.
