Dash Light Dimmer Functionality
Discussion in 'Gen 3 Prius Main Forum' started by stream, Mar 31, 2010.
  1. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I noticed today that the dash light dimmer control doesn't affect the dash light intensity when the headlights are off. Turn it up or down, no change. It does work when the headlights are on.
    I seem to recall that the dimmer on my Prius used to control the dash light intensity both when the headlights were on and off (and this is how it's worked on previous cars), but no longer.
    Am I imagining this? Does the dimmer work on your car when the headlights are off?
  2. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    When my headlights are off the only thing that changes with the dimmer is the intensity of the Start/Stop button. When the headlights are on it changes the intensity of all dash lights. I just had to go check though Stream, never noticed it did nothing with the lights are off (except the start buttons intensity...)
  3. stream
    2,977
    452
    Long Island, NY
    Thanks for checking.
  4. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    Mine is just like yours.
  5. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    The dimmer on my V only adjusts dash light intensity when the headlights are switched on. When they are off, the dash shows at full intensity.
