dash lights: BRAKE, ((!)), ABS
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by LKasdorf, Aug 3, 2022.
  1. LKasdorf
    LKasdorf Junior Member
    77
    24
    Waterford, VA USA
    2005 prius: I redid the rear brakes and bled them. I still have these lights on the dash:
    BRAKE
    ABS
    Dr Prius and Torque do not report any error codes. Will these go away after a while? Or do I need to reset them with TIS?
  2. ChapmanF
    19,034
    When there are brake warning lights and the scan tool being used isn't showing the trouble codes, then getting the codes by the Tc to CG jumper, count light blinks method is usually the fastest way to get on track to diagnosing the issue.
    PriusCamper likes this.
