Dash lights flashing while car is off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by silentraven37, May 20, 2026.
  1. silentraven37
    silentraven37 Junior Member
    Massachusetts
    Just went to go check the brakes on my wife's 2008 Prius, turned the car back on and now all the dash lights are flashing. The gear indication lights and the fuel gauge lights are just flashing even though the car is off. But technically the car is still kind of on because you can move the windows up and down.
    What is going on with this car and how do I fix it?
  2. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    If the car does not turn off correctly, this is an indication that the combination meter is going bad. Take a look at this thread, https://priuschat.com/index.php?posts/2293037
    Try holding the button for 5 second or more to see if the car will turn off correctly.
