Dash MPG different than Actual MPG different t
Discussion in 'Gen 3 Prius Fuel Economy' started by tearl2991, Sep 12, 2016.
  1. eman08
    eman08 Active Member
    360
    192
    US
    The MPG Avg is alot like the gas guessing gauge, just an estimate. It will either be higher or lower vs calculated manually. I did 338 on 6 gallons while my display reads 51.4 MPG Avg. But by hand it's actually 56.3 MPGs.
  2. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    I have never seen or experienced this to be true of a Prius. The displayed on all 4 of my (2 current, 2 past) Prius have always shown high compared to calculate mpg.
    I would agree that the displayed could be roughly estimated to be 2-4 mpg less than calculated, but not the opposite.... Just my experience over the years :)
  3. Mendel Leisk
    42,368
    I guess gen 2 calculated mpg could vary wildly from displayed, to either side, due to the complexities of the bladder tank. But yeah, over 2 or 3 tanks, those variations will cancel out, and you're left with the very consistent positive bias.
  4. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    True! I never considered the craziness of the bladder tanks of the Gen 2's.
    But, wasn't the op posting in a Gen 3 thread? I could be mistaken though..
  5. Mendel Leisk
    42,368
    True, missed that.
    My take, no matter how many mishaps you encounter, say your good samaritan son shoots $10 in, you have a finicky pump, whatever: as long you can keep track of how much gas went in, eventually, spanning multiple tanks, you get back-on-the-beam.
    That's one reason I tend to fill up as soon as it's below half full: I want to be the one doing the tank up.
    Blizzard_Persona likes this.
  6. CR94
    CR94 Senior Member
    2,837
    1,244
    Northwestern S.C.
    Therefore, with any generation, the most accurate estimate we can have of true mpg for any one tank-full is neither what the display says nor distance divided by raw pump reading. Instead, that best estimate is what the display says, TIMES a correction factor based on several consecutive fill-ups. For my car, for example, that factor seems to be around 0.950 to 0.955.
  7. tearl2991
    tearl2991 New Member
    US
    Most recent update... My dash said I was getting 44.6 mpg. I put on 188 miles on the car and used 6 gallons. This is equivalent of 31 mpg actual. Something is definitely not right in my opinion
  8. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    30% variance from displayed to calculated mpg?o_O Wow! Something has to be wrong. I never saw worse than 9% off during the dead of winter, avg was around 7% on my Gen 3's...
    And it is possible to actually get 31 mpg in a Gen3 if you drive it like a madman and only do very short trips on under inflated tires...:unsure:??
  9. tearl2991
    US
    I agree, tire pressure is 35 in front 33 rear and we drive very eco friendly I just don't know what to do
  10. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Check your 12 volt battery first (crappy mpg is most often a good indication of a dying 12v), then add a few pounds of Air to your tires... For starters.
  11. Robert Holt
    Robert Holt Senior Member
    1,313
    890
    Severe mis-alignment could increase rolling resistance , but you should see odd , uneven wear patterns on the edges of your tires. This factor can be negated by a true 4-wheel alignment but that costs $100(?) at the dealer.
    Otherwise, it comes down to checking each fluid and operational component of the HSD system, a tedious task.
  12. tearl2991
    US
    I have checked the battery it's right around 14.1 running
  13. KokomoKid
    KokomoKid Member
    115
    82
    Florida and Indiana
    Reset one of the trip odometers, and run about 10 tanks through the car. Add up the total gas used, and divide it into the miles. If the mpg readout shows anything other than about 4-8% higher than your actual mileage, something is wrong with the electronics involved in the readout, or the odometer.
    As I remember, the trip meters only go to 999.9 miles and start over, so you'll need to keep track of the thousands to do this.
  14. KokomoKid
    KokomoKid Member
    115
    82
    Florida and Indiana
    Could someone have syphoned gas from your tank? That would hurt actual gas mileage, without affecting the readout.
  15. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Are you asking me (since you replied to my post twice) or the OP whom I was attempting to reply to..??
    But yeah, something is up with the op's car? I have no clue...
  16. KokomoKid
    KokomoKid Member
    115
    82
    Florida and Indiana
    Sorry, I was really replying to the original poster.
  17. Mendel Leisk
    42,368
    Siphoning is nigh impossible now I think.
    Regarding calculation of tank mpg, if you want to be sure, use the odometer, not a trip meter, it's "safe as houses". The trip meter is prone to accidental reset.
    For sure use the trip meter, but just for a feedback, and as a cross check when doing the math with odo.
  18. KokomoKid
    KokomoKid Member
    115
    82
    Florida and Indiana
    Yeah, to syphon you'd need access to the car to open the gas door, or break the gas door. I don't know what hapoens with the hose, re. the bladder thing.
  19. bingee3
    bingee3 Active Member
    171
    105
    Michigan
    Do you always fill up at same station ?? Might try another station as their PUMPS might be off ,,, of course by accident of course ,,, I had 2 bars showing , filled up OMG it took 10.3 gallons ,,, I'm guessing , that's how they paid for their new car wash ,,,
  20. fuzzy1
    10,722
    That is the inverter output (analogous to the charging system of a traditional non-hybrid) voltage, not the battery voltage.
    Measure the battery voltage when the car has been shut off for several hours.
